Anyone ever replace REAR Axle shaft 9.75 ? ABS Ring question
Old 11-01-2013, 04:19 PM
royb's Avatar
royb
royb is offline
the factory rear axle shaft ABS ring is all metal
the FORD replacement rear axle shaft with ABS ring has plastic around the teeth. Is the plastic supposed to be removed ?
2010 F150 FX4
okay i got it figured out - the ABS system uses magnetic sensors that read the metal ring with teeth . this type of system can read the teeth through the plastic so it doesn't need to be removed. the plastic is there to reduce dirt build up in the teeth .
Old 11-01-2013, 08:14 PM
royb's Avatar
royb
royb is offline
never mind - i got it figured out.
the plastic stays the speed sensor is magnetic and reads the teeth through the plastic . the plastic is there to keep the dirt out of the teeth.
Old 11-01-2013, 08:17 PM
royb's Avatar
royb
royb is offline
by the way the CPU converts the magnetic reading from the speed sensor into volts then makes the adjustments to the various systems .
trukerdanz
1983 - 2012 Ranger & B-Series
02-13-2015 07:04 AM
mankypro
12-09-2013 10:47 AM
woody1003
19
01-05-2008 07:09 PM
redrock233
07-30-2006 11:16 PM
BigWhiteTurdVan
Aerostar
03-17-2003 11:15 PM
Quick Reply: Anyone ever replace REAR Axle shaft 9.75 ? ABS Ring question
