2004 f250 4x4 hubs
OE replacement hubs are the only hubs I know of that will retain the ESOF 4wd working as your does now.
Warn, Mile Marker and Yukon make aftermarket manual hubs. The Yukons are supposed to be the strongest. As said if you go with any of these manual hubs you will have to get out and lock/unlock the hubs manually. Also you will have to plug the vacuum lines and hub fitting going to each hub to prevent contamination.
2008F-250
1999 to 2016 Super Duty
01-28-2009 10:34 PM
