4X4 Hub Question
Old Jan 4, 2006 | 06:21 AM
MooseHead Rider's Avatar
MooseHead Rider
4X4 Hub Question
OK guys. I am trying to figure out the auto hubs vs. the warn hubs. I know that the warn hubs are manual locking, meaning I need to get out and turn them to lock them in. However, this is where I am getting confused considering that with this truck I have always used the auto switch with the hubs. When you get out and manually lock the hubs does this engage the 4X4 or do you still have to turn the switch on the dash?
I know in my previous trucks I had the floor shifter to engage the 4X4 after locking the hubs and you could leave the hubs locked if you wanted. I am just not that familiar with this vacuum stuff and how it works. If you can lock the hubs and still use the switch on the dash what happens to the vacuum mechanism?
I think I know the answers but I want to be positive and hence the question. I'd rather sound like a bonehead than not know for sure.
Thanks,
Bob
Old Jan 4, 2006 | 06:36 AM
blueeyes2478's Avatar
blueeyes2478
You would still have to turn the swicth on the dash.However you will have to plug the vac lines going to the hubs now,as you would not need them.
Old Jan 4, 2006 | 08:06 AM
arninetyes's Avatar
arninetyes
Manual hubs are much more reliable, too. And the Warn hubs are much better than stock.
Old Jan 4, 2006 | 08:15 AM
nodakford's Avatar
nodakford
I replace my auto hubs with the Warn Premiums. Very easy job to do. I would recommend the Warn hubs as a replacement.
Old Jan 4, 2006 | 08:28 AM
MooseHead Rider
Is the reason everyone changes them due to problems they see? I have had to get the vacuum stuff fixed twice now, but it has always been at the beggining of the winter when I get the thing serviced.
Is there another advantage to this other than people seeing problems with the auto hubs?
Bob
Old Jan 4, 2006 | 09:53 AM
dunbar15's Avatar
dunbar15
Bob
I had problems with my 99 F250 and 00 F350 hubs binding up the 99 was auto and the 00 is manual hubs. They can be disassembled and greased , had a mechanic to it on one of my hubs on the 99. From what I have read on this site your best bet is to go with warn manual hubs and be done with it, they are much better than stock. Dont know if warns have the problem of binding, someone with experience on the warns can chime in on that.
