1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2004 f250 4x4 hubs
Old 11-01-2013, 04:19 PM
Bearlb67's Avatar
Bearlb67
Bearlb67 is offline
2004 f250 4x4 hubs
Hello all, quick question my 4x4 hubs are frozen, I have decided to go after market... My question is I have electronic shift on dash, and "lock/auto" hubs. If I buy the "free/lock" hubs wills they work?
Thanks
Old 11-01-2013, 04:55 PM
02TB250's Avatar
02TB250
02TB250 is offline
No they will not. You will have to get out of the truck and manually lock the hubs to engage 4wd.
Going with the manual hubs will allow you 2wd low
Old 11-01-2013, 08:21 PM
dkf's Avatar
dkf
dkf is offline
OE replacement hubs are the only hubs I know of that will retain the ESOF 4wd working as your does now.
Warn, Mile Marker and Yukon make aftermarket manual hubs. The Yukons are supposed to be the strongest. As said if you go with any of these manual hubs you will have to get out and lock/unlock the hubs manually. Also you will have to plug the vacuum lines and hub fitting going to each hub to prevent contamination.
Old 11-01-2013, 09:15 PM
SC_Hoaty's Avatar
SC_Hoaty
SC_Hoaty is offline
Some folks believe that manual hubs are superior to the Electronic Shift on the Fly (ESOF) system that Ford provided. One less thing to go wrong. The ESOF is vacuum actuated, and can be defeated by a vacuum leak elsewhere on the truck.
speakerfritz
22
05-07-2014 12:16 PM
Nabors
08-02-2012 04:26 PM
2008F-250
01-28-2009 10:34 PM
sgrol
04-30-2006 09:38 PM
MooseHead Rider
01-04-2006 09:53 AM
Quick Reply: 2004 f250 4x4 hubs
