White smoke at start?
Old 10-26-2013, 04:31 PM
Pridnjoy's Avatar
Pridnjoy
Pridnjoy is offline
Never any white smoke before today- this morning used block heater and had some white smoke and now this afternoon with 58 degree outside temps getting lots of white smoke at start up and until warm. A whole lt! Checked coolant and seems a bit low. All numbers on my Edge Insight seem inline.
Whats going on?
Thanks.
Old 10-26-2013, 05:42 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Rusty Axlerod is offline
Smell the smoke. Best way is to pull your hand in the smoke for a few seconds until it's wet then smell your hand. Coolant smell is likely EGR cooler, fuel smell may be injector issue. If it's a coolant smell you can pull EGR valve and check for coolant there. Parking with the front of the truck a little lower than the rear may help also.
Wide outside temperature fluctuations and high humidity can sometimes lead to a lot of condensation that will dry out as it warms up. Exhaust residue will be more like water with some soot in it, not much smell.
Old 10-26-2013, 06:27 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
what Year??
Hows the FICM Voltage??
Old 10-26-2013, 10:12 PM
Pridnjoy's Avatar
Pridnjoy
Pridnjoy is offline
2005 and FICM right at 48.5 while driving. Now trying to figure out if its white or blueish white...
Billows out when starting and smokes good until its been running for at least 5 mins. Started it earlier when it was already warm and had same results. Seems to completely go away after about 5 mins. Have MBRB turbo back with gutted cats and doesn't sound like the same hair dryer effect it previously did if I recall correctly. But boost is fine and drives fine, just excessive smoke.
Old 10-27-2013, 10:06 AM
Pridnjoy's Avatar
Pridnjoy
Pridnjoy is offline
I also checked my DTS codes and there are none...
Old 10-27-2013, 11:22 AM
p51mustang23's Avatar
p51mustang23
p51mustang23 is offline
It's getting colder out in many parts of the countrywhich causes lots of morning dew so this would make sense. Except I think he said it happens even with a warm start?
Old 10-27-2013, 11:59 AM
POORBOY1964's Avatar
POORBOY1964
POORBOY1964 is offline
Out of curiosity do you have CCV (crank case vent) to atmosphere?
Old 10-27-2013, 12:17 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
Rusty mention to pull EGR I would try that
Also pull the Down pipe off the Back the turbo and see if its dumping oil in threw the turbo
Old 10-27-2013, 12:46 PM
Pridnjoy's Avatar
Pridnjoy
Pridnjoy is offline
Ugh. Just checked coolant reservoir and it is empty. Pulled EGR valve and it is sooty and only lightly gummy...
Old 10-27-2013, 12:59 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
when did you check it last??
Pretty good chance time for EGR and OIL Coolers
Old 10-27-2013, 01:04 PM
Reaper76's Avatar
Reaper76
Reaper76 is offline
if you pulled your EGR and it's wet that means it's time to replace the cooler or delete the system.
Old 10-27-2013, 01:09 PM
jswartz84's Avatar
jswartz84
jswartz84 is offline
Do you know what your oil and coolant temp spread at operating temp is by chance?
Old 10-27-2013, 01:32 PM
Pridnjoy's Avatar
Pridnjoy
Pridnjoy is offline
My EOT and ECT delta runs around 7-8 degrees consistently. I checked coolant reservoir yesterday and it was a good level. Drove about 25 miles last night. This morning checked and was empty. Only seems to billow smoke after starting and the for about 5+ mins...
Old 10-27-2013, 01:56 PM
jswartz84's Avatar
jswartz84
If you can't tell if there is coolant in the intake you can park nose down and let it sit overnight. Pull the Egr valve the next morning and check for coolant.
With a delta of 7-8 I don't think it would be necessary to replace the oil cooler(some people have and some haven't and turned out fine) but you are almost other when you pull the intake manifold.
Old 10-27-2013, 04:00 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
Ya looks like his EGR Cooler Sprung a Leak 05 was squre so
Have you checked ECT EOT at cold soak??
blackeyed1
6.4L Power Stroke Diesel
01-30-2015 04:00 PM
429poweredf350
06-20-2014 11:13 PM
Robil7
06-08-2011 10:06 AM
elkohcaliente63
1999 to 2016 Super Duty
03-15-2011 11:43 PM
powerstroke219
04-19-2008 08:34 PM
Quick Reply: White smoke at start?
