How much should it cost to have fuel pump replaced?
#35
That just absolutely STEAMS me!!! You should call them and raise hell.
#36
Nah, hopefully they drive it back there and explain how some redneck from the mountains came down and fixed it in the driveway - for free.
Thanks for the reps. I'm taking stuff to measure fuel pressure, rebuild fuel bowl, change fuel pump (I have a new pump in the toolbox) and AE. If we need to drop the tank, I may have to try and do it on my way back up next week so I can start in the AM.
Daisy and I will be there early afternoon tomorow and I'll let ya know what we find. Some of you are on speed-dial anyway! Y'all can let them know we are not as scary as we look!! And try to explain why I told her I wouldn't charge them for my time...
#37
It's all good, and a return to an earlier ethic where neighbors "helped out".
Pop
#41
Ok, plenty of fuel pressure and volume so no issues with pump or tank. The old filter looked half eaten by an animal - she wasnt kidding when she said it was bad!!
We did a Buzz Test cold and #6 was muted and gave us high to low side open. Truck had dead miss consistent with injector not working, but eventually smoothed out. All 8 buzzed good when warm (running good).
Rotational Velocity was ~4.0% on #3 & #8 and we got Cylinder Contribution codes for those cylinders...
#42
#43
Dumb phone...
Its running pretty good now. A couple GP codes, a small coolant leak and some likely boost leaks - but nothing urgent.
They have a WEIRD transmission issue though!! Mandy, you should start a thread about that.
Speaking of which, Mrs Vegan is quite educated. She has clearly done alot of reading and knows more about her X than most people I know. Its easy to want to help someone so eager to learn and understand these unique engines!!
#44
Dumb phone...
