6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Battery Light came and Replaced Alternator
Old 10-23-2013, 01:19 PM
4X4 IN REFUGIO's Avatar
4X4 IN REFUGIO
4X4 IN REFUGIO is offline
My battery light came on and ended up Replacing the Alternator. All is well.
However....for several weeks, the idle speed has been fluctuating from normal at 650rpm up to 850-900rpm's. Sometimes if it was idling high you could restart the truck and it would idle normal again. But by the time you got to the next light it would idle high again. Could not figure out what was going on and there were no codes.
This past weekend the battery light came on so I had the alternator tested and it tested bad so I replaced it.
Battery light no longer comes on and the truck idles normal at all times now.
Was thinking that the alternator was failing all along and that's why the engine would idle higher to get voltage up from alternator.
Anyway... thought I would share my experience about the engine idling high..
All is well now till my rebuilt aftermarket alternator fails....and it will cause they aways do.
Old 10-23-2013, 06:06 PM
slowmans's Avatar
slowmans
slowmans is offline
Good to know, what did you put in and what did you pay?
mdr617
1997 - 2003 F150
11-10-2017 12:16 PM
mchristian
07-08-2015 05:43 PM
npccpartsman
Escape & Escape Hybrid
13
01-10-2011 09:08 AM
dober
1997 - 2003 F150
04-10-2010 09:02 PM
duden123
1999 to 2016 Super Duty
20
09-10-2006 12:32 PM
Quick Reply: Battery Light came and Replaced Alternator
