1986 351 W 4wd-oil pump
Can the pan be removed as it sits, or do I have to do major things like pulling the motor on this F250 4wd? Series of unfortunate events-the oil pump shaft is gone. No idea where it is. Only thing I can think is that it was in the base of the distributor, slightly caught, and when I removed the distributor, it came up, then fell out, back down inside the motor. I put in the new distributor without realizing anything was wrong and at some point during my cranking, it could not anymore turn over...some hand manipulation with a rachet on the crank, I got it to move and later figured out I had no pressure. Looking down inside the distributor hole, the shaft hole-its nowhere to be seen.
1-hoping it fell down into the pan
2-if my theory is right a new shaft fixes the issue
3-if somehow it sheared off, then a new shaft won't go into the pump properly and I'll have to remove the pan.
Hope to get er done by the weekend.
I think I have heard of people leaving it in there with no problems. Originally it had a little clip that bumps against the casting of the block, keeping it from coming out of the pump. Two things can happen.
1. Someone had the engine apart and somehow lost the clip off the shaft or
2. The shaft was so stuck in the bottom of the distributor, that after pulling and jerking with a lot of force to get it out, the whole shaft comes out with the distributor and the clip has slid off into the bottom of the pan.
Elvis66
13
05-14-2011 03:03 PM
66flareside
17
03-18-2006 01:52 AM
d9t351_400
01-28-2003 05:55 AM
