2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
pesky p0420
Old 11-18-2013, 02:33 PM
jdm5630's Avatar
jdm5630
jdm5630 is offline
pesky p0420
Check engine light has been turning on for a few days then it'll turn off for a few days. I took it to get read and the code was p0420. I have replaced all spark plugs and coil packs. Is my cat shot? Why woukd the CEL be turning off and on? This is on a 07 expy. It was misfiring a few months ago that's when I replaced sparks and coil packs.
Old 11-18-2013, 03:04 PM
berry1234's Avatar
berry1234
berry1234 is offline
No need to replace the coils and plugs again. It could be a number of thinks. Leaking injector, bad cat, etc. I suggest you take it to a shop you trust. Throwing parts at these things are often costly and fail to solve the issue.
Old 11-18-2013, 03:17 PM
jdm5630's Avatar
jdm5630
jdm5630 is offline
Is it safe to drive 600 miles in it? I need to make a trip this weekend. The truck runs great. Its just the light keeps turning off and on
Old 11-18-2013, 03:51 PM
berry1234's Avatar
berry1234
I can't say. Unplug the battery for 15 minutes and see if the code stays out. If it drives fine, doesn't buck or idle poor, fluids are ok, it should be fine.
Old 11-18-2013, 10:58 PM
montecarlo31's Avatar
montecarlo31
montecarlo31 is offline
So a quick run down, is your O2 sensor voltage changing quickly or slowly? ECT in the proper range? What is the mileage on this rig? You said a few months ago you replaced plugs and COPs, how long did you run with a down cylinder, is itpossible enough fuel was dumped to damage the the O2? Was the failed COP/Plug on the same side? Remember as no one has pointed out this is a bank one failure so it's just 1/2 of the engine having issues. I would drive it personally if it idles and seems to run fine you just may burn more fuel than you want to.
Old 11-18-2013, 11:47 PM
bunky383's Avatar
bunky383
bunky383 is offline
You could try to swap the downstream o2's side to side, if the code changes to bank 2, then you know your o2 sensor is shot.
Old 11-19-2013, 02:20 PM
jdm5630's Avatar
jdm5630
jdm5630 is offline
Montecarlo, I have 101k on the odometer. We ran it maybe 50 miles with a down cylinder. How do I check O2 censor voltage? And the ECT range?
Old 11-19-2013, 02:42 PM
bunky383's Avatar
bunky383
bunky383 is offline
If you want to get dirty, go underneath the vehicle and back probe the wires with a multi-meter. While your under there smack your converters and see if they sound like theres a million broken pieces in there, bad news if it is. Or stay clean and plug in a reasonable scan tool to your obd2 port.
Old 11-19-2013, 05:05 PM
jdm5630's Avatar
jdm5630
jdm5630 is offline
I need to buy a multimeter but I did get under the truck and smacked the converters. it doesn't sound like anything is loose in there
Jim98F150
1997 - 2003 F150
25
08-19-2019 06:46 PM
JoshsF250
1999 to 2016 Super Duty
09-02-2011 08:16 PM
CounterMaker
10-06-2009 04:43 PM
TennesseeGuy
Modular V8 (4.6L, 5.4L)
12-29-2005 12:15 PM
Quick Reply: pesky p0420
