I have a 2006 F250 4x4 with 100k. I had Ed repair my FICM but I still Have a long crank when cold. My question is how long should it take for the FICM to sync. it takes at least 5 or more seconds before it shows on my scan gauge that it is in sync. Thanks for any info.
What about CAM and Crank Sync? Have you programmed SYC? You have to have Cam and Crank Sync BEFORE you get FICM Sync. (FSN)
Ok so it took 7 seconds to start. I turned it of and restarted and it started right up. If this is normal that's fine. But I have heard other 6.0s start cold and it didn't take that long. Or at least it didn't seem that long. When it is worm it only takes 1 or 2 seconds.
Kinda what I thought Its should start as Fast as it Did the Second time "ALL THE TIME"
Its alittle on the Long side Mine starts within about 2 seconds
7 Seconds would seam like an Eternity to me
Last time my truck took longer then the normal 2 second it was Broken
I think whats happening is the HPO Rail is Bleeding off when the truck sits and cools off
2006 has the Wavey rail and is known for D-Plug and stand pipe issues as well as some the Nipples Orings are starting to show signs of going Bad as well
One thing are you letting the Glow Plug Light go out before you crank right?? if so Refer to the Above 2 Posts^^
Ok ICPV KOEO is .24 cold idle is 1.15. when I crank to start RPM is 162 ICP climes to over 500 by the time I get to 6 seconds and it starts. My question is this normal.
