1951 Ford F1 resurrection, jag IFS LT1, EFI, T56, etc
#242
having lived in Buffalo the first 32 years of my life, I've dealt with more rust than I care to ever see again. All the road salt ate vehicles like a rat eats cheese. Surface rust starts in 3-4 years, rust thru a year or two after that. I had a 72 Vega I bought new, it actually rusted so badly that it literally broke in 1/2 in 6 years! The SE is somewhat better, but the humidity and heat still deteriorates from the top down unless stored under cover. That's why I went to the SW (NM) for my 99.9% rust free truck. Well worth the trouble and expense for the pleasure of working with solid steel.
#243
As far as this truck I bought two, this one is the rougher one. I was not sure if I was going to save it or dump it, but I decided to save it. No going back now, it will be on the road this summer if all goes as planned. Killer is the bad winter, until this snow melts I cant even get the chassis outside to paint.
#244
Left corner work continues, the only good thing is the passenger side doesnt look as bad as this side..I think.
Rivets drilled out and welds cut, rear cab mount removed.
Made a pattern of the inner cab corner and then removed it, cut back the floor and found a lot of damage to this side of the crossmember.
This is as far as I am going as far as teardown on this side, repairs are next. Before cutting out the crossmember rust I am going to repair the rocker, tack weld it, and hang the drivers side door to check fitment. If all looks good then the rocker will be welded solid and the repairs can begin one layer at a time.
#246
First piece made, simple patch with a step in it for another piece that fits over it. Tacked in place to the corner before going to far.
Repaired the upper hinge mount and hung the drivers side door. First time a door has been on this cab in many years.
Gaps and fit looks good, opens and closes fine so the door opening is good and the repairs can continue.
#247
Left rear corner work continues, yes I hate rust.
2 layers of metal sandwich the rocker panel from what I could tel from the damaged area. Outer piece went over the rocker and tied to the inside of the rear pillar. I dont have a spot welder so I use plug welds.
Same deal with the inside piece. This was part of the floor panel but I will make it separately, plus I made it larger than the factory part stiffen up the rocker. Plug welds on this one as well.
next will be to cut the rotted parts out of the crossmember and repair it.
#249
#250
Thanks, I am doing my best to keep focused, but when I need a break I read up on the other builds going on here..then I want to go do more work! Build threads are great motivators.
That is regular metal primer, I am using a wirewheel to clean things up and then spraying with primer on hidden areas. Once all of this is cleaned, seams sealed, primed, and hit with raptor liner it will outlast me, especially since there are no plans on winter driving. I think the reason the floor was so bad was because it has been sitting with no doors for many years so water just sat inside everywhere.
#253
I thought my cab corners were bad, yours are a little worse. At least my rear floor is solid, but a po decided to rivet a big perice of sheet metal over a small hole and made a huge hole in the process on the back cab wall. Thats gonna be the hardest part of my cab. Luckily one of my parts trucks has a pretty solid back wall, so im gonna cut that out and use it.
#254
#255
