1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
1997 expedition dies after starting
Old 10-07-2013, 11:39 AM
jawsok's Avatar
jawsok
jawsok is offline
1997 expedition 4.6l 4wd starts and then dies almost immediately. Any ideas on where to start?
Old 10-07-2013, 12:31 PM
timbersteel's Avatar
timbersteel
timbersteel is offline
Any tune-up performed? Sounds like weak fuel pressure.
Old 10-07-2013, 12:40 PM
alloro's Avatar
alloro
alloro is offline
Received 4,198 Likes on 2,433 Posts
Once it starts, slightly press on the gas pedal to raise the idle. Does it still stall then, or only at idle?
Old 10-07-2013, 01:37 PM
Icefan71's Avatar
Icefan71
Icefan71 is offline
I had the same problem. If I gave it gas it would stay running. If I let it idle it would die. I had a bad IAC, idle air control valve. I replaced it and that fixed the problem.
Old 10-07-2013, 08:01 PM
jawsok's Avatar
jawsok
jawsok is offline
It will run rough if I press on the gas pedal. I will check on everything everybody told me. Thanks on all comments. I will let you know in the next few days
carlos813
Florida Chapter
08-05-2013 06:10 AM
gregnorwood
06-14-2007 01:34 PM
BlacJack
18
09-14-2004 07:58 AM
gkateley
05-05-2002 05:59 PM
shomby
11-17-2001 04:09 PM
Quick Reply: 1997 expedition dies after starting
