Ford IBC, again...
#47
Bump and comment. This is an excellent thread to read if you have a wiring fault message. RV tech has a very good process to follow if you are short on equipment and/or knowledge. I have been chasing the "wiring fault" for months. It went from a fault to a hard short. I had to go wheel to wheel to find it but with some help from a friend we found it in the rear axle. I'll attach a picture or two. But, had I listened to a couple folks on this thread and done a microscopic wire inspection I would have found it with a lot less trouble. There was just enough evidence where the wire from the left rear wheel goes into the axle toward the right rear that I should have seen it. Also, as I was working there I could smell the electric burn residue. Thanks to all who contributed to this.
ndlawrence
07-16-2013 05:53 PM
Mud Doc
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
06-24-2013 02:59 AM
