If i buy the diamond eye that bolts to the stock cat is it gonna be worth it to spend the extra money on a cat delete kit or will it hurt it to have the gutted cat (empty housing) there in the system? if so how much will it hurt it?
iirc diamond eye has 4 different DPs... Regular steel and stainless options for cat and bypass.
Ok... price has gone up... I seem to recall paying about $50-$60-ish for the kit.
Richard
Originally Posted by 77mud
If it was 50-60 id definitely be buying it haha.
He wants 99 for it for the OBS stroke's and then its 20 and some change to ship it to me so even if i have to buy a 45 sweep new i will be no where near the price he wants, Plus i dont want the filter cover really.
I went back and looked, it was $77 for the kit, and $14 for the cover exactly 2 years ago next week. Not to be unexpected though, the goal is to make money and im sure his suppliers costs and operating costs have risen as have everyones.
It won't hurt a thing to keep the gutted cat in there, but the delete pipe will make a much cleaner looking system.
Aslong as it wont effect me i have no problem with looks haha. Function>look
Originally Posted by fordpride
You can leave the gutted cat and the stock muffler. The muffler is a straight through design meaning very little restriction.
Thanks, guys on Powerstroke nation trying to convince me it's usless to put on a DP with out going to a 4" exhuast which i find hard to believe when mine is already 3.5"
Im into it a filter which was 37 bucks shipped. Thanks for the info though
I believe that the gutted cat still hurts flow slightly. Enough to notice? I doubt it. The air just isn't going straight through, it'll tumble around in the cat a bit before getting through it. I'd get rid of it myself, but if you need it for visual inspection, gut it.
Did my tymar intake and i also took my y pipe off and took a porting bit to it and it made a nice improvement, i cleaned up and smoothed out the pipe on the inside where the pipe is pushed inside and welded in and i was surprised at how much of a lip was in there on two of those.
Yeah its worth it, at first when i was thinking about doing it i figured it was going to be a waste of time and not worth even messing with but i though i had better at least take it off and look at it to see what it even looks like and then i went at it hahahah
Thanks. I decided to just buy the filter and make my own elbow since i had access to 4" sweeps. to bad they were all sch 80 so i hit it with the grinding wheel on a bench grinder and sanded down tell it fit the hose and filter snug.
Im gonna be doing the DP soon once i recoup some money since i just bought a car, but even with just the filter i noticed a improvement
Yeah the filter sure makes a difference, the other day i stuck a 6637 filter in my wifes truck i just stuck it in the black rubber hose and it made a noticeable difference
To bring up a mod that hasn't been discussed in a few years.. If you're looking to pick up a little bit of power until you can get a chip or programmer, give the 10k mod a try. Several members of this board used to try out lots of different combinations of the 10k mod and posted about them, so there should be plenty of information out there to reference. I'll have to look later and see if I can find any of the old threads. The 10k mod should be good for a little bit of power. Probably around 10hp if I had to guess.
