serpentine belt...
Old Oct 14, 2013 | 06:31 PM
kupiec20's Avatar
kupiec20
serpentine belt...
belt broke and was only a year old. so when i went to put a new one on i noticed the fan had major play in it....just about hanging on.
so my question is....is it a bad fsn clutch or water pump?
my guess is thats why the belt broke. any thoughts? ty
Old Oct 14, 2013 | 06:32 PM
BuckHammer's Avatar
BuckHammer
Probably water pump. Are you leaking coolant?
Old Oct 14, 2013 | 06:38 PM
kupiec20's Avatar
kupiec20
leaks EVERYTHING but coolant. lol
i dont think it was but ill chk again.
i dont even know how the fan is still on.
Old Oct 14, 2013 | 06:47 PM
BuckHammer's Avatar
BuckHammer
Mine had a BUNCH of play when my water pump was bad, but I was leaking coolant, too. If the clutch is moving with the fan, I'd say that should tell the story. Like, if everything from the pulley on down the line is wiggling in unison, I'd say your water pump is shot.
Old Oct 14, 2013 | 07:21 PM
fordpride's Avatar
fordpride
Most likely the pump is bad. Make sure to check the fan for bent blades. If any are bent it'll cause it to be unbalanced and wear out the bearings in the pump
Old Oct 14, 2013 | 08:14 PM
madpogue's Avatar
madpogue
When you move the fan through its play, does the pulley move as well?
xrsfsho
May 27, 2016 09:48 PM
monstrs
Feb 28, 2015 11:59 PM
Cowgirl Caddilac
Jun 7, 2013 09:22 AM
78bigunns
Oct 20, 2005 08:23 AM
caperail
May 10, 2005 04:34 PM
