Brake pedal sticking
Old 09-22-2013, 07:05 AM
CountryBumkin's Avatar
CountryBumkin
CountryBumkin is offline
I replaced the master cylinder and power booster a few months ago with Ford NOS parts (82 F250 4x4). Everything was working perfectly - but I just don't drive the truck enough - which is the cause of everything/anything that goes wrong with my tuck. Now the brake pedal is sticking (down/applied) when I step on the brake pedal.
I have to get my foot under the pedal and lift up or the brakes will be dragging.
I assume the problem is in the booster since lifting on the pedal to release the brakes would have no effect in the master cylinder. The pedal linkage itself is not sticking. I don't recall if I can get to any moving parts inside the booster. I'm thinking I may be able to spray some lubricant into the area where the booster piston slides (i.e. remove booster and spray into the end that connects to pedal).
What do you think - any other ideas?
Old 09-22-2013, 07:12 AM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,721 Likes on 1,392 Posts
All I know is they always have a warning on these things about something that can get out of place inside the booster where the master cylinder goes. They warn you do not pull the little shaft out of the booster or some sort of "reaction disc" can come out of place. Did you pull the shaft out of the booster?
Old 09-22-2013, 09:27 AM
CountryBumkin
I don't think so - but I don't remember now. I know it worked fine after the brake job. I only drive the truck when I need something large from Home Depot or such, so the truck doesn't get used much any more. It's been a couple of months since the brake work and then the other day I got in and the pedal was sticking.
I guess I just need to pull the booster out and either find something wrong that I can fix or replace it.
Old 09-22-2013, 11:59 AM
mattparham1's Avatar
mattparham1
mattparham1 is offline
I wold check too make sure your vacume line one there isnt leaking first, that maybe be your problem the little rubber gromets are horrible on the boxes.
Old 09-22-2013, 01:57 PM
CountryBumkin
I could see how a bad/leaking hose would cause a hard pedal - but not a sticking pedal. What are you thinking?
Old 09-22-2013, 02:08 PM
mattparham1
Nothing in paticular just an easy thing to check forehand. I have kinda the same provlem mine returned really slow and when I redid my vaccume lines it worked alot better, not sure if it was related or coincided but it solved it when I replaced the lines.
mckoloum
05-16-2019 03:53 PM
Rusty_S
10-01-2016 11:34 AM
hulaman
13
06-24-2016 11:24 AM
jasonmesq
01-17-2016 11:48 PM
reno138
03-13-2014 08:12 AM
Quick Reply: Brake pedal sticking
