Can someone help with this hood latch
All looks fine to me in the photo, my first guess would be the dowel need to be adjusted to make longer. It probably is not making it past the catch lever in the latch to hold the hood down. The latch to the left is factory and there as a safety, that is a lot of steel to catch wind if it is not held down.
Last post was right on. Even when it works right on my 55, it is hard to get both latches to release easily at the same time to raise the heavy hood. Doesn't help with my bad shoulder. Could be the bent safety latch on the left is keeping the main latch from connecting and latching the hood down properly. Possibly remove the safety latch for straightening if needed and see if the mail latch then connects.
No it's not stuck it moves freely. It just doesn't move very far which made me wonder if some of it was missing...Hard to tell what's going on in there when you cant see it. I need a small child with a flashlight ;-)
On mine it kinda of tough. Pull safety latch in, lower hood, reslease safety latch AFTER it clears hood. Walk around and push hood hinges down on both side, hold regular latch open, push down on the nose of the hood, hold hood down and release latch....if everything is lined up it should be latched shut.
tacson
16
11-26-2013 09:25 AM
