need help with my 65
My 65 f-100 has a 97 ford truck 5 speed in it. what i need to know is how do i get my 65 speedometer to work? Which cable do i use and what gear? Thanks for any help you can give. Thanks Don
PS. I also put the rear end out of the 97 in my truck. The 97 had a 300 six in it. My truck has a 302.
Speedometer DRIVE (on the output shaft) and DRIVEN (end of the cable) gears based on trans type, rear axle ratio and tire size.
You'll have to measure the length to figure out which cable you'll need, as it won't be the same length as the original, due to the swapped trans.
I gave you the info inre to figuring out which gears will be correct, and said the original cable won't be the correct length, as the trans has been changed.
wavetrain75
08-07-2019 10:41 AM
Grandpa's66
07-17-2019 06:12 AM
rw84f150
11-30-2004 08:35 PM
