Cab swap and Maryland MVA question
Has anyone done a cab swap or something similar in Maryland? I just got my tags for my truck this morning and asked the teller if there were any forms and she said that since there's a VIN on the motor and elsewhere, MD doesn't require any paperwork if the cab is swapped. Can anyone back this up for sure? I thought at one time I saw a form online for the MVA for custom vehicles, but can't find it on there. Thanks a lot.
It depends on the year. before 1980, the serial numbers were not always in the dash. Some were on the door, some were on the door jamb, some under the hood, some in the glove box
1981 brought great wisdom ( not really)
Everything got a 16 digit serial number, starting with 1 for United states, 2 for Canada, and 3 for Mexico
This plate was pop riveted to the inside dash metal, visible through the lower driver's side window
The pop rivets are "special" and not available to the public
In the state of Md, to change a cab after 1980, you must have the tittle for both cabs. You take the finished truck to Glen Burnaie MVA, and have it inspected.
They then take both tittles, and submit you with a new serial number for the truck
There is also a serial number on top of the frame rail passenger side front, and another on a cross member of the frame. I never found that one.
Trucks manfactured after 2001, have serial number on the inside of every panel on the truck, including the door panels.
The lady at MVA was incorrect about the serial number on the engine
There is however a date stamp, with factory where built, and what line it came from
This is true also for the transmission
Front and rear drive axles have a tag, states year, gear ratio, truck plant and line it came from
Okay, sounds like a nightmare from what you guys are saying. But looking at the website, it seems all I need is the title for the truck (frame) and then a bill of sale for the cab. Have they changed the rules? I will call the MVA and make certain I don't need a title for the new cab, because I more than likely can't get it.
- Proof of ownership – The ownership document must be for the vehicle frame used in building the reconstructed vehicle:
- If the frame is new, the certificate of origin included with the kit is required.
- If the frame is from a used vehicle, a title for the vehicle in your name or a title that has been properly assigned to you is required.
- If the frame is from a salvaged vehicle, a salvage certificate in your name or a certificate that has been properly assigned to you is required.
- Other documents that may establish ownership are:
- Registration document and bill of sale – ONLY if the state from which the frame was obtained did not issue a title (usually because of the vehicle’s age).
- Application – You may use either the back of the Maryland title, if applicable, or the Application for Certificate of Title to request the new title (and registration, if applicable). When the Maryland title is used as the application form, complete the section entitled Application for Title and Registration.
- Proof of purchase price – You must submit the bills of sale and/or receipts for all parts and labor.
- Odometer disclosure statement - You may use the manufacturer’s certificate of origin or the title to document the mileage of the vehicle. A separate odometer disclosure statement may also be submitted.
- Application for Assigned Vehicle Identification Number (if applicable) - A new vehicle identification number (VIN) may be assigned to the completed vehicle. The Maryland State Police will install the new VIN plate after they have inspected it.
- Maryland safety inspection certificate - A safety inspection is required if the vehicle is being registered at the same time (most cases).
the destroyed a family members truck cab and other parts looking for serial numbers
good luck
any thing I can do to help hit me up-let the forum know how it turns out
Here's a post from another current thread. Not Maryland, but pretty much the same all over the US
Ford Truck Enthusiasts Forums - View Single Post - Junkyard find, how do I handle, advice please
OK, so I just called the MVA just now, and got transferred to the state police safety inspection office in Glen Burnie.
According to the guy I spoke with, I need the title for the original truck and a bill of sale for the new cab (this is also in the language on the MVA website, quoted above). I don't necessarily need the "new" cab's title, which is good. He said they know where the VIN plate on the frame is, but I've been all over this truck and not seen another VIN plate.
I'm really trying to finish up this truck, and now I at least know I can buy the cab at a JY and not have to buy a whole truck to get one with a title. I'd like to swap the cab before the end of the year. Thanks again for any advice.
Melbatoast
18
05-19-2020 10:17 AM
bugsydog
21
02-23-2019 10:18 AM
Gary P
08-18-2016 04:40 PM
