Arkansas Chapter Join Chapter Leader: Kramercd
shift lever removal
Old 09-13-2013, 04:13 PM
Old_Crow's Avatar
Old_Crow
Old_Crow is offline
shift lever removal
Anyone know how to get the shift lever off a 5 speed trans in an '89 F150 4x4?
There's a big nut on a threaded pin where the lever attaches to the trans. We've loosened the nut, but the pin won't turn or back out with mild use of a hammer(not ready to start wailing on it yet).
Need the lever off so we can locate the new carpet on the floor before we cut holes in it.
Old 09-16-2013, 04:35 AM
Calli's Avatar
Calli
Calli is offline
Try this link. Maybe it fits your question?
How to Remove the Floor Shifter Lever From My F150 | eHow
Old 09-18-2013, 04:46 AM
Old_Crow's Avatar
Old_Crow
Old_Crow is offline
It was almost that simple, just not that obvious. Lever has a tapered pin in it where it fits over the stub shaft coming out of the trans. Had to remove the lock nut from the tapered pin and put it on the threads on the other side of the lever and use the lock nut to remove the tapered pin. Also found that on Ehow.com. Believe that's the first time I've ever got a helpful answer from them.
Thanks.
Old 11-08-2013, 04:47 PM
LHO39's Avatar
LHO39
LHO39 is offline
Here is a YouTube video showing the shift lever removal.
Old 11-11-2013, 11:23 AM
Old_Crow's Avatar
Old_Crow
Old_Crow is offline
Thanks, we got it. WTF's wrong with a threaded shaft with a jam nut on it? Works on my Jeep.
Old 11-12-2013, 12:20 PM
zhilton's Avatar
zhilton
zhilton is offline
Come on Walley, well all know "the Ford way is better". Don't believe me? Just ask some of those clowns in Dearborn and their questionable designs.
Jeff64F100CrewCab
06-03-2018 10:11 PM
cowboywanabe
03-04-2012 08:56 PM
vanwashe
02-28-2012 09:09 AM
410 Highboy
07-25-2011 08:12 PM
G2IC_Wraith
1983 - 2012 Ranger & B-Series
04-11-2004 07:05 AM
Quick Reply: shift lever removal
