sitting on the highway
powersteering pressure line gave out. Blew the fitting out the side of the pump. Got the half I could off to take to carquest. Now I'm waiting for the wife to feed the babies and come get me.
I'm sure glad there is a mechanical link between my wheel and wheels. Sorry for a pointless post but, I've run out of tools on board and parts to put on. :-(. Sure am wishing I had my tool box installed instead of my o shoot bag.
hope everyone is having a good morning.
Received 3,700 Likes
on
has anyone had issues with the pressure line leaking at the p/s gearbox? i've ended up buying a set of crowfoot flare nut wrenches. i torqued it down pretty good. (i'm 6' 220lbs with a 3/8 ratchet).
it's just a flare fitting right, not something that looks like it but requires an o ring or something? i was topping of every morning, 50 miles. and every where i park there is a dinner plate sized leak. i'm tired of refilling.
At the gearbox mine was just straight but at the pump there was a little o-ring. I did have to go back and re-seal the pump side with some plumbers tape. I had a fair drip going until I put that on there. You might try the same thing on yours. Also, I would undo the bigger fitting next to it and move it out of the way then get a line wrench on the smaller one so you can use the leverage better. just my opinion though. Crow wrenches never seem to work as well as i want them to.
Gilley
11-06-2013 05:08 PM
|WYG|SS
08-19-2010 06:19 PM
tejomakash
02-10-2003 06:56 PM
