Kick down seal C4
Kick down seal C4
Hello there again!
My plan is to eventually put a 4 speed in my 70 f100. I currently have an automatic c4 that us leaking pretty bad out of the kick down arm.
A friend of mine says that this seal is relatively easy and inexpensive to replace. He also says I can do this myself. Do you guys agree? Do I need a special tool? Anything I should l should be aware of before I try this?
Thanks
Craig
Thanks
Craig
Hello there again!
Thanks
Craig
Thanks
Craig
can easily be changed from the outside. The seal D5AZ7B498A will cause you to drop the pan. There is a nut on the inside that holds the Shift Shaft in.
jimpennycuff
02-19-2007 04:07 PM
leadhead
07-18-2002 07:23 PM
