Factory Tachometer Question
Okay cool thanks, 1986f150six.
I purchased the entire cluster because I wanted a tach, my speedometer needle was broken, and the shift indicator assembly was not functioning.
The cluster should arrive in two days. If it doesn't work correctly, I can use the old circuit and hard wire the tach.
Thanks
Thanks
One other thing, under the hood, check next to the Duraspark box for a two wire plug. It has one black and one green wire. Trucks without tach usually do not have the wiring going from this plug to the engine. If you do not have it, the green wire goes to the coil negative terminal, and the black goes to engine ground.
That definatly makes sense Matt. The ebay description did not clarify weather or not the cluster came from a 4.9 or 5.0.
I just found a thread... hear is the infrimation...
A V8 coil fires 33% more often than a 6cyl, or the 6 cyl fires 25% less than a V8, whichever way you want to look at it.
V8 @ 2,000 RPM = 8,000 coil fires
I6 @ 2,000 RPM = 6,000 coil fires
On the back of the tachometer, there are two grounds. One is marked with an "8" and the other is a "G". The V8 application makes use of both grounds. The 6 cylinder does not use the "8" ground. All of this is handled by the original wiring.
https://www.ford-trucks.com/forums/s...d.php?t=942555
I used copy and paste, sorry I haven't figured out how to quote on my iPhone.
vintageracer31
06-17-2018 09:10 PM
Szoob
02-02-2004 09:58 AM
pikiluvi
11-23-2003 06:30 PM
