1950 F1 with flathead 6 stalling when driving: Advice?
I am a total newbie to owning an old vehicle and bought a 1950 F1 with the orginal flathead 6 in June, so I am trying to learn. I am also not that knowledgeable about working on engines. So with that I will do my best to explain to my problem and ask for advice.
My truck always starts on the first attempt and I usually let it warm up for a minute or two before driving if I haven't driven in a day or two. When I push the choke back in, the idle gets really low and feels/sounds like it could die at any moment. If I let it sit, it will stay running but idles so low you expect it to die, but if I drive it, it will often stall when I come up to a stop and push in the clutch. I find that I either have to press the gas to keep it going or pull the choke back out and let the idle run much higher. I didn't have this problem a month ago.
Anyone have any thoughts as to what may be the problem and how I mite fix this issue? So if someone has any advice, I would be grateful, but know you might have to spell things out a little more since I am not very knowledgeable on working on motors. Thanks for any help anyone is willing to give me.
Thbifeb
Thbifeb
Welcome to the world of old trucks Thbifeb!
This could be several issues - need to start with the basics. Is there good fuel flow? If the gas line is clogged, the truck will start and idle but may not rev. If the fuel filter is old, replace it. Is the carb clogged? Varnish build up can clog jets. Is the timing off? This would cause the truck to run rough. Is there a vacuum leak? This would cause problems during acceleration.
So, check your fuel line, clean the carb, check the timing, and check for vacuum leaks.
Oh, and post pics!
Happy Motoring!
DW
Oh, and post pics!
Happy Motoring!
DW
Thanks for the info. I will try some of those ideas. I was driving today and was crossing a major intersection and I lost power and just couldn't get the truck to go. It took me a out 30 seconds to cross the intersection and was out in the middle when it went red. No matter how much i pressed on the acelerator, the truck wouldn't go faster. Was going about 2-3 miles an hour in second gear. So, would that give any more clues as to what would bethe problem?
Let me know. Thanks
Let me know. Thanks
Initially, the symptoms sounded like a vacuum leak.
Try closing the choke just until the idle speed picks up and see if it runs better. If it does, it is running lean. That can be a vacuum leak or (fuel) idle circuit.
Failure to move across the intersection may be fuel delivery also (as in accelerator pump failure or simply not enough fuel in bowl).
My suggestion is that you should look for a vacuum leak, double-check timing, then verify fuel pump delivery rate and then, if it pushes enough fuel (and it looks clean!!), rebuild the carb.
I hate recommending you run it at all rich, but something I found with my rig... the accelerator pump in the rebuild kit being nitrile was junk went back to the leather. that fixed 90% of my problem. the other 10% richen it up just a touch (I had it perfect on with a vaccuum gauge and it would bog out like that - just a touch rich, and I mean a touch like 1/8 turn it would run fine...)
as always when running out of ideal settings check your plugs to make sure you aren't so far out that issues show up in your configuration.
Vacuum
Many of you have recommended checking the vacuum for leaks. Here is something I have noticed, that may give those of you who know way more than I do some more info to potentially diagnose my issue. The wiper will work, but I was driving in the rain the other day and as long as I had my foot on the gas, the wipers wouldn't work. If I took my foot off the accelerator, the wiper would work (not very fast, but it worked). So, does that additional information give anyone a better thought as to why I may stall when pushing in the clutch when coming to a stop or not getting enough speed when in 2nd or 3rd or when shifting between the two?
Again, I appreciate all the help people are giving me. As I pointed out in my initial post, I am not very good with mechanics so I am trying to learn. I have never worked on cars/trucks in my life, so I am about as clueless as they come, but I want to try to learn. Thanks for all the thoughts.
Let me know if anyone else has other ideas based on my vacuum.
Thanks
Thanks
Here's an easy way to find a vacuum leak:
Disconnect or (gently) pinch off vacuum lines such as wipers, brake booster, PCV, etc. Your vehicle may not have all of this stuff. Use a stub of plugged hose or a tubing cap to seal off the vacuum source connection.
Idle vehicle.
Spray WD-40 or similar compound around intake, carb base, distributor vacuum line, etc.
If the engine idles up, you have found a probable vacuum leak.
Idle vehicle.
alaricsept
06-13-2018 10:09 AM
78workhorse
10-20-2007 12:56 AM
Billy Brethren
24
08-26-2007 11:34 PM
