''51 Gas pedal linkage & parts.....am I missing something?
Old 08-05-2013, 09:34 PM
pineconeford's Avatar
pineconeford
pineconeford is online now
Knuckle Bandage Sales Rep
Hi guys,
My shop manual has no detail in this area....nor does the illustration in the LMC catalog.
I'm putting together my transmission cover (1951) and have begun to attach the gas pedal system to it. I think I'm missing something, let me explain...
OK, for parts I have on hand and I believe to be stock: I have the original pedal itself and the two screws that hold the pedal to the trans cover, the rubber floor boot, the 'Z' bar that mounts to the firewall, bellcrank and two linkage rods (a short and a long one) .
What keeps the pedal from flopping around? The pedal has two threaded studs underneath it. What goes there and what are they for?
The end of the 'Z' linkage has a springy ball stud at the end that doesn't seem to fit into the pedal.
I'm stumped as to how to connect the pedal to the 'Z' linkage and what springs I'll need to get the whole connection from pedal to carb to move and return as designed.
I'd appreciate any photos, references and spring locations or other related info.
I have a stock 6-cylinder if that matters.
The previous owners of the truck rigged up some crap and I'm returning the truck to stock configuration. I never saw what it looked like originally.
Thanks in advance, Tom in Maine
Old 08-05-2013, 09:46 PM
tinman52's Avatar
tinman52
tinman52 is offline
Welder User
The little ball on the end of the Z bar thingy should snap into a hole on the top of the pedal. It fits pretty tight so it won't fall out. That is all that connects the two. Carb return spring I don't recall...
Old 08-05-2013, 10:17 PM
52 Merc's Avatar
52 Merc
52 Merc is offline
Received 2,469 Likes on 1,408 Posts
This is going to sound crazy, but on the flat 6 trucks, the carb linkage return spring connects to a cotter pin in the floor/firewall at the passenger's feet, and to the linkage.
Old 08-06-2013, 05:28 AM
pineconeford
Hmmm, thanks guys - now I'm getting somewhere.
Wayne do you (or anyone) have a picture or diagram of that cotter pin & return spring arrangement?
Tom
Old 08-06-2013, 11:11 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
'51 Gas Pedal Linkage & Parts ~ Am I missing something?
Originally Posted by pineconeford
Hi guys,
What you're missing is the 1948/56 Ford Truck Parts Catalog, available on a CD from hipoparts.com
Old 08-06-2013, 08:22 PM
pineconeford
Thanks Bill,
You are correct and also a wonderful source of information. I appreciate all the time you take to answer our questions and provide source data.
My nexxxxxttttt question that arises for anyone has to do with the Throttle control and cable that is on the dash. Back in the day...what was this used mainly for? The operators manual on page 17 says .."to set the engine at any given speed".
I can understand if a truck had a PTO, but if it didn't - was it a poor man's cruise control or something to adjust for altitude, winter warm up, or simply to have another **** to mess with?
Tom
Old 08-06-2013, 09:37 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Jolly Roger Joe is offline
Tom
Here's a pic of the cotter pin on the inside (passenger side) of the firewall. May be too close up to tell. If you have a heater, you won't see this head on. The cotter pin head is visible inside the engine compartment on the firewall. Or maybe you'll just see the hole.
On the far left side of this pic in the center next to the speedo cable, you'll see the location of the cotter pin, its head is empty, as this is taken before I knew how the return spring was supposed to be attached (the PO obviously didn't either).
Old 08-06-2013, 09:40 PM
Jolly Roger Joe
Tom
Well, one can speculate many uses, but I've used mine to rev the engine with my foot on the brake to take off going uphill. Pull on a little throttle and let out the clutch, start moving forward and release the brake.
olguy317
08-19-2016 10:40 AM
Chevmn56
11-27-2013 05:08 PM
cars2cool
06-16-2008 09:02 PM
Christopher2
12-27-2004 06:07 PM
Quick Reply: ''51 Gas pedal linkage & parts.....am I missing something?
