1996 f150. When hot it acts like its flooding. Will hit on a couple of cylinders and i hold it wide open and will usually pick up 4cyls and i can drive it where within a mile or 2 it clears completly out. Latey it has been losing one cyl till it completely cools off after which it starts just fine. Do i have injectors sticking open with the heat. ? Definately worse in summer. I can usually spray a little ether and get it to clean out at its worse but today that didnt work. If i dont turn it off its fine but sure as i do when its hot and let it set for more than 5min or so rough start or complete flood like today.
I had a fuel pump relay go north in my old Honda and it acted the same way. Pull the computer codes before you do anything else. Self diagnostics are a wonderful thing.
That's the exact thing that happened to me with leaking injectors, but they would clear up in a few minutes.
If started immediately after a hot shutdown, it was okay.
It would blow black smoke out the exhaust when it was happening. That shows it was leaking gas.
No codes.
Does seem to do a little better when i put a qt of atf in tank. I guess its just time for injectors or at the least rob an injector rail at parts yard.
Isnt there a feature on these trucks that disables the fuel pump on a hot start to keep from flooding? Could I retard the timing just a little to help on hot start ? If it runs on ether then dies seems its a fuel.delivery problem too. Done it again today. 3 hours later fired up like nothing happened.
