Radiator Hose for Y-Pipe boots?
Old 07-19-2013, 08:28 AM
Badatit's Avatar
Badatit
Badatit is offline
1997 4-Door F350 7.3 PSD 2WD E4OD Auto 3.55 280,000miles
I Pulled my Turbo, replaced the wheel. Y-Pipe boots were pretty bad. I went to parts store all they had in the size I needed was radiator hose. I got it, cut two pieces to length and installed. Truck has never run better.
Before I did this Boost numbers never got over 7 psi.
During test drive, I took my foot out of it several times at 17 psi(tied in near MAP)/2900 rpm/1100 on pyro.
6637 intake. 3" DP, 4" Diamond Eye Exhaust w/cat delete.
These numbers look OK? and does anyone see a problem with using Radiator hose for Y-Pipe boots.
Thanks folks.
Old 07-19-2013, 10:06 AM
blageurt's Avatar
blageurt
blageurt is offline
Well I think the oil will eat it eventually and it will not last that long...I would go to a Heavy Truck Store , buy 1 ft. of the correct silicone hoseand cut the pieces you need....
Old 07-19-2013, 10:29 AM
RÖENTGEEP's Avatar
RÖENTGEEP
RÖENTGEEP is offline
FOREIGN GURU
Arrow
Id do what he said. Or buy OEM from IH or Ford dealer.
Old 07-19-2013, 10:59 AM
Badatit's Avatar
Badatit
Badatit is offline
Thankyou both.
Old 07-19-2013, 11:13 AM
Arcturus's Avatar
Arcturus
Arcturus is offline
Old 07-19-2013, 12:46 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
Originally Posted by Arcturus
Welcome to the forum for both of you.
And yes thats a very good choise and good quality hoses.
Old 07-19-2013, 03:57 PM
strokin'_tatsch's Avatar
strokin'_tatsch
strokin'_tatsch is offline
I've actually been running some "radiator" hose on my IC for about a year and a half now. It works pretty good. Just do a CCV mod to keep the oil out of them.
These "boots" that we made with the coolant hose are sticky as hell. As in they don't come loose from whatever they got clamped to without using a lot of force and cussing. I see no reason to get rid of them unless it would just be to make it easier to get the IC pipes in and out of the boots.
Old 07-21-2013, 01:13 AM
fordpride's Avatar
fordpride
fordpride is offline
Where in the hell did you find a 3" ID rad. hose and what did it come off of?
Old 07-21-2013, 02:36 AM
strokin'_tatsch
They have it in long straight sticks at the auto parts stores. Looks like something used on old antique tractors. Lol. I think Cody got like 3 or 4 feet of it. He's using it on his puller too.
Old 07-23-2013, 04:24 PM
Badatit's Avatar
Badatit
Badatit is offline
Ford House wanted over 50.00 ea. I told,em thanks but no thanks.
I ordered a couple from Riff Raff. I'll have them on hand when I need them.
I hooked up to my (I need to weight it/ Title says it's 8900 lbs) 5th wheel Saturday morning and pulled it 200 miles up to San Marcos Tx.
Truck is running pretty good. from what I was able to discern pulling it up there, and back down...
Tranny temps never got over 168* (sat. 9am-1pm)on the way up...65-70 mph at first...Pre-Turbo Pyro numbers were a little scary. Had to keep it between 1000-1200 to maintain speed I backed it down to 60-65 mph keeping them a couple of hundred lower (for the most part) 850-1150 or so.
I used OD when I could on the way up. Guess-timated 12.5 mpg. OD-On ( going up grades), I'd throttle back around 65 mph OD-Off and ease back into the throttle around 60 mph and ease off to keep Pyro off of 1200.
Tranny temp never got over 170* (mon. 12pm-4pm) on the way back...I used OD Very little on the way back. guess-timated 10.5mpg
OD-Off /Cruise set at 56 mph/2250 rpm/Pyro would peak at the top of grades at 1200*
How much would a chip affect these numbers and speeds?
Your thoughts please.
Thanks Fellas.
john fin
22
04-13-2012 09:39 PM
Hdfunone
6.4L Power Stroke Diesel
16
04-12-2011 06:01 PM
fortuitous24
03-10-2008 12:34 PM
learpilot
01-21-2006 07:44 PM
scf100
03-30-2005 11:37 AM
Quick Reply: Radiator Hose for Y-Pipe boots?
