2000 EX. V-10. Replaced upper and lower hoses. One more hose coming from the radiator resevoir hose connected to the bottom of the radiator. No local auto parts have pics of system.Wwhat do you call this hose and where can I get a diagram of the hoses and part #s.
I know what hose your talking about and I'd also like to know the part # for it. I need to replace it.
The EX is a 2000. The hoses have never been changed. Doing some maintenance so it doesn't burst while I am on the road. I do not drive my EX much. Stays in the garage and only comes out to go on trips or haul the boat. Thanks for the help guys.
on your 2000 your lower hose has a tee with a hose going to the engine oil cooler... they are clamped with plastic clamps that can break but are also glued to the fitting... the one from ford (OEM) does seem to be of better quality than the ones from a third party supplier...
