Power steering pump for 390
Wally, I'm curious what all that welding is under the alternator in this picture? Has the frame been modified? In fact, I'm curious about a lot of things in that photo, is that your truck? If it is why has the radiator horseshoe been cut at the bottom and what is it mounted to, there doesn't seem to be a crossmember under it and it looks like it has been moved back (or the engine is very far forward)? What is that cloth covering at the bottom that looks like it is going end up right thru the radiator?
I believe the regulator 1oldtimer mentioned is for the steering pump pressure not the alternator. If you are using a saginaw pump, the pressure is adjustable internally with an inexpensive kit available from Summit and others.
Wally
78ford351m
15
12-05-2008 08:25 PM
workingdog
15
11-22-2005 03:06 PM
Gidde Up
08-19-2003 10:11 PM
Scouder
03-24-2002 08:26 PM
