cycling and no a/c
Old 06-11-2003, 05:51 PM
paradiddle's Avatar
paradiddle
paradiddle is offline
cycling and no a/c
I had no a/c so I thought I would add a can of R134. (it had been converted professionally at a shop by previous owner.)
The clutch still cycled often. So I checked the power plug to the clutch and it had 12v at all times. (I had checked the pressure switch before hand). I'm in the middle of doing a compressor swap (almost as cheap as just a clutch and I don't need the pullers). Am I going in the right direction?
I just got guages but I had already pulled the compressor. Should I just reinstall the old compressor and recharge and check pressure Or continue with the swap?
__________________
Old 06-11-2003, 10:41 PM
paradiddle's Avatar
paradiddle
cycling and no a/c
never mind I fixed it.
I put the old compressor back in and rechagred it with the guage this time.
I get 48 deg out of the vent
Old 06-13-2003, 02:22 AM
mpippins's Avatar
mpippins
mpippins is offline
cycling and no a/c
IF you open the system you MUST vacuume the system. It will not work right if not, and eventually will damage the pump, that is if you can even get the pump to engage. I belive it is sapose to be like 28psi of vacuum at sea level, but i have done really well with 25psi
02expy
06-29-2016 03:52 PM
1998Ranger25L153CID
1997-2006 Expedition & Navigator
03-16-2016 05:18 AM
jbtecnico1
Escape & Escape Hybrid
05-14-2015 12:19 PM
phurst
33
06-02-2010 12:13 AM
jessidog
1983 - 2012 Ranger & B-Series
10-27-2008 07:04 PM
Quick Reply: cycling and no a/c
