Missouri Chapter Join Chapter , Leader:77&79F250
anyone have any suggestions?
Old 07-01-2013, 06:13 AM
zstangkrewson's Avatar
zstangkrewson
zstangkrewson is offline
I have pulled the 4.9 out of my 1990 ford f140 and have put in its place a 1995 5.0 v8, everything is bolted up and now we have an issue with the dash wiring and Especially the ignition switch wiring, does anyone here have any experience cross wiring these two wire harness to get the ignition to work?
any help is GREATLY appreciated.
Old 07-01-2013, 07:22 AM
earthquake68's Avatar
earthquake68
earthquake68 is online now
Just hook up the power feed to the Dura spark to switched battery, and the solenoid trigger from the ignition switch to the "S" terminal on the solenoid. It's not a complicated system.
Old 07-01-2013, 07:47 PM
zstangkrewson
LOL have you seen how many wires are under the dash??? it took me almost an hour to remove teh dash, 45 min of it was unhooking wiring! but ill give it a looksy! thankyou for the reply!
Old 07-01-2013, 08:03 PM
earthquake68
I know there's plenty of wires under there, ...but only two matter.
Old 07-02-2013, 09:30 PM
zstangkrewson
there was 8 wires coming out of my old switch, and now there is 12 wires from the new one, old has 2 yellow, new has 4, hmmm this could get interesting.... had to cut on my mint dash to get the new instrument cluster to fit, looks pretty good i think..
Old 07-02-2013, 10:07 PM
earthquake68
Use a test light to see which wire goes to starter trigger. Same thing for the switched battery.
Old 07-09-2013, 07:32 PM
zstangkrewson
no luck yet, am going to swap cabs and fuel/tailight harness and see if i get anything, right now all i get is a check engine light and thats it...
can crank the motor with the selenoid, but no fuel or spark.
on another note, i test drove a 97 f150 with the 5.4, had a rattle in the motor, fro mwhat ive seen on youtube and google, sounds liek the cam phasers are worn out, so i think, not for me...
CottonTexas
06-08-2018 10:17 PM
zstangkrewson
07-03-2013 07:22 PM
62unibeastie
1961 - 1963 F100 Unibody
10-20-2011 03:58 PM
STEVE1103
Electrical Systems/Wiring
04-16-2007 03:13 PM
rwjr
1978 - 1996 Big Bronco
02-21-2007 05:03 AM
Quick Reply: anyone have any suggestions?
