Inner tire tube
Inner tire tube
So the other day my truck got flat tires, i went on craigslist got 4 35x12.50x15 Bfgoodrich all-terrian t/a 12ply with about 90% tread left for 40bucks not each for all of them. They do have some dry rot however (mostly in between the treads, along with one has it on the side wall) . Im thinking of putting tubes in the tire? Any suggestions thanks.
Throw em on with no tubes, Tubes in radial tires is a worse idea then running dry rotted tires, the side walls flex and will pinch the tube. If anything the dry rotted outer will fly off before the cords and the inner rubber fails. also they are 12 ply, that's a heck of alot of ply..... Just keep an eye on them. Ran many a trailer tires like that and most are still holding fine.....
Diesel Rod
Diesel Rod
mel2000f150
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
06-11-2009 11:31 AM
