302 mount towers for a 79
Old 07-03-2013, 12:12 AM
1979 300i6's Avatar
1979 300i6
1979 300i6 is offline
Im planning on switching out my 300i6 for a Mildly built 302 and been having Problems finding mount towers, any ideas? It's a 4x4
Old 07-03-2013, 05:34 AM
jim collins's Avatar
jim collins
jim collins is offline
E-Bay , Craigs List , Pick-n-pull , no reproductions made that i know of.
Old 07-03-2013, 05:29 PM
ChaseTruck754's Avatar
ChaseTruck754
ChaseTruck754 is offline
do a little searching around to see if the towers may be the same between your 300i and the 302. I THINK they are the same towers in the 2wd so maybe the are in the 4wd too???
Old 07-03-2013, 07:06 PM
SuperDutyScaler's Avatar
SuperDutyScaler
SuperDutyScaler is offline
2WD AND 4WD TRUCKS USE DIFFERENT FRAMES SO THE MOTOR MOUNTS WONT FIT
Old 07-03-2013, 08:02 PM
dw_wanno's Avatar
dw_wanno
dw_wanno is offline
On the F-150 4x4, the I-6 towers and the V-8 towers utilize different mounting locations in relation to the coil spring bracket. They both share some bolts for the coil spring bracket, just different bolts which have different spacing pattern between the 2 towers. This prevents you from just unbolting, moving the tower, and reinstalling in correct location without modification to the tower. You will want to find a set of towers (any one correct me if I'm mistaken) from either a '78-'79 F150 4x4 only, that has a 351/400M (V-8) engine.
Old 07-17-2013, 12:23 PM
ChaseTruck754
My comment was meaning maybe the 300i mounts off a 4wd would be the same as the 302. Not that 2wd and 4wd are the same.
It seems dw_wanno has come in with some good info.
My question for him would be - would the mounts off a 78/79 bronco with the 315/400m work? Should be the same as the F-150 4x4 correct?
Old 07-17-2013, 02:03 PM
73FOMO's Avatar
73FOMO
73FOMO is offline
The 302 will fit the I6 perches (if the I6 perch is indeed the same as 2wd), it will just sit the motor up higher. I believe the I6 perch is the same as FE perches. The 302 perch sits the engine much lower in the engine bay.
Old 07-17-2013, 02:12 PM
351coupe's Avatar
351coupe
351coupe is offline
The I6 perch is not the same as the one you'd need for a 302.
I do have a set of the perches that you need for a 4wd.PM me if you are still looking.
Old 01-05-2014, 12:59 PM
1979 300i6's Avatar
1979 300i6
I'm interested in buying mounts for a 78-79 302 4x4 f150 if anyone's got them and is interested in selling them just send me a PM
Kai
12-12-2018 03:34 PM
78ford100
06-29-2004 03:18 PM
pacemaker9k
01-31-2003 01:46 PM
denise
12-19-2002 06:58 PM
tetraruby
03-15-2002 12:08 PM
Quick Reply: 302 mount towers for a 79
