2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
is it normal for oil level to be a little low?
Old 07-04-2013, 01:24 PM
jdm5630's Avatar
jdm5630
jdm5630 is offline
So I checked the oil level today and I noticed its about a quart low. I don't have any leaks. Ive been using Valvoline maxx life high mileage. Engine has 98,000 miles. its never been low like that before. Is it normal?
Old 07-04-2013, 01:30 PM
JWC 3's Avatar
JWC 3
JWC 3 is offline
How many miles since last oil change ? Lots of engines use a bit of oil , and if too long between changes , it will show . Ck your pcv also , that can cause oil consumption . If you are going 5k between oil changes 1 qt is not bad . If only 200 miles , that would be different .
Old 07-04-2013, 01:35 PM
jdm5630's Avatar
jdm5630
jdm5630 is offline
Its been about 3500 miles. I usually change at 4,000
Old 07-04-2013, 01:43 PM
JWC 3's Avatar
JWC 3
JWC 3 is offline
One qt in 3500 miles is not "excessive" . But could be an issue . Ck your PCV and crank vent . Double check for leaks and do not use too thin an oil ( it will burn away faster ) . I would go ahead and change it also and start keeping a close eye on it to be safe .
Old 07-04-2013, 01:55 PM
jdm5630's Avatar
jdm5630
jdm5630 is offline
Do you recommend switching to a 5w/30?
Old 07-04-2013, 02:05 PM
JWC 3's Avatar
JWC 3
JWC 3 is offline
My 04 calls for 5w30 . I use 10w30 in the summer and 5w30 in the winter , for the last 100k . I would see no issue going to 5w30 insted of 5w20 . Or even 10w30 if used hard or in a hot climate .
Old 07-05-2013, 10:20 AM
alwaysfords41's Avatar
alwaysfords41
alwaysfords41 is offline
04 Expedition? 5.4? My manual calls for 5W-20.
Old 07-05-2013, 06:46 PM
JWC 3's Avatar
JWC 3
JWC 3 is offline
Sorry , I should have said my 04 Mounty . I was just using the recomendations of mine as an example . I should have been more clear .
mrshark
Escape & Escape Hybrid
05-22-2012 09:43 PM
dagren99
12-09-2011 08:04 AM
tonyford
08-18-2010 08:04 PM
chrowen
2004 - 2008 F150
01-06-2010 06:31 PM
79CEEJAY
18
03-26-2004 04:15 AM
Quick Reply: is it normal for oil level to be a little low?
