Neutral safety switch
Hello,
i´m from Germany and new here. Sorry for my bad english.
My new car is a Ford F150, 1972, 360. I´m searching for a wiring diagram for the neutral safety switch. Because someone cut the two red/blue cables. One goes to the starter relay and the other one was cut directly behind the NSS plug.
Greetings, Michael
Greetings, Michael
Michael, your English is excellent.
I think you'll find what you need here. 1972 Ford Truck Wiring Diagrams - FORDification.com
Applications: 1965/77 F100/350.
GREEN SALES CO. in Cincinnati OH has 17 = 513-731-3304 / 800-543-4959.
Green Sales (greensalescompany.com) ships "across the pond" by Fed-Ex.
All I do is look up the part numbers, list the sources that have them. Green Sales has the lever, will ship to Deutschland via Fed-Ex.
NSS selector lever (7B097 ~ shown at the far right lower in pic below NSS) snaps onto the shift tube thru a hole in the mast jacket (steering column shroud).
ok, sorry, i was looking at www.greensalescompany.com. But i don´t know how to order at the Homepage. i also found this part at lmc and dennis carpenter....
Do i have to remove the steering housing or ist it possible to install the part without removing?
Do i have to remove the steering housing or is it possible to install the part without removing?
You don't have to remove anything to install NSS lever, but it's a PITA to install. Fitting your mitts under the dash while layin' on the floor makes you wish you were a contortionist!
Lets here a AMEN to that yes it just clips on you'll need an inspection mirror just to see what's going on. It would be easier to remove the NSS for right now just to give you more room.
Green Sales contact info listed on homepage: G2172@hotmail.com / Green Sales ships "across the pond" .. dunno if anyone else does, why I recommended them.
Tbonedog
08-09-2017 02:12 PM
Notmeofficer
03-25-2014 03:05 AM
