Neutral safety switch
Old Jun 26, 2013 | 02:49 AM
kunzendo's Avatar
kunzendo
Hello,
i´m from Germany and new here. Sorry for my bad english.
My new car is a Ford F150, 1972, 360. I´m searching for a wiring diagram for the neutral safety switch. Because someone cut the two red/blue cables. One goes to the starter relay and the other one was cut directly behind the NSS plug.
Greetings, Michael
Old Jun 26, 2013 | 07:11 AM
MavSprint's Avatar
MavSprint
Michael, your English is excellent.
I think you'll find what you need here. 1972 Ford Truck Wiring Diagrams - FORDification.com
Old Jun 26, 2013 | 08:29 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Welcome to FTE
C7TZ-7A247-A .. N/S Switch (Motorcraft SW-600) / Obsolete ~ Available NOS and from auto parts stores.
Applications: 1967/77 F100/350.
Note: No F150's until 1975.
Old Jun 27, 2013 | 03:08 AM
kunzendo's Avatar
kunzendo
Hello,
the NSS is ok but the control pin is broken. So i have to by a new one and everything is good :-)
Thanks,
Michael
Old Jun 27, 2013 | 08:27 AM
NumberDummy
Originally Posted by kunzendo
The NSS is ok but its selector lever is broken. So i have to by a new one and everything is good.
DOTZ-7B097-B (replaced DOTZ-7B097-A & C5TZ-7B097-A) .. NSS Selector Lever / Obsolete
Applications: 1965/77 F100/350.
GREEN SALES CO. in Cincinnati OH has 17 = 513-731-3304 / 800-543-4959.
Green Sales (greensalescompany.com) ships "across the pond" by Fed-Ex.
Old Jun 27, 2013 | 08:48 AM
kunzendo's Avatar
kunzendo
Does anybody know who to install the NSS Selector lever?
@NumberDummy: Is it possible to order some parts from you?
Shipping to Germany..
I visited your Homepage but i didn´t find a shop.
Michael
Old Jun 27, 2013 | 08:58 AM
NumberDummy
NumberDummy: Is it possible to order some parts from you? No. I visited your Homepage but I didn't find a shop.
I don't have a homepage, just a profile on FTE. I do not sell parts, because I have no parts to sell. I've been retired since 1997.
All I do is look up the part numbers, list the sources that have them. Green Sales has the lever, will ship to Deutschland via Fed-Ex.
NSS selector lever (7B097 ~ shown at the far right lower in pic below NSS) snaps onto the shift tube thru a hole in the mast jacket (steering column shroud).
Old Jun 27, 2013 | 09:19 AM
kunzendo's Avatar
kunzendo
ok, sorry, i was looking at www.greensalescompany.com. But i don´t know how to order at the Homepage. i also found this part at lmc and dennis carpenter....
Do i have to remove the steering housing or ist it possible to install the part without removing?
Old Jun 27, 2013 | 12:02 PM
NumberDummy
Do i have to remove the steering housing or is it possible to install the part without removing?
Green Sales contact info listed on homepage: G2172@hotmail.com / Green Sales ships "across the pond" .. dunno if anyone else does, why I recommended them.
You don't have to remove anything to install NSS lever, but it's a PITA to install. Fitting your mitts under the dash while layin' on the floor makes you wish you were a contortionist!
Old Jun 27, 2013 | 10:29 PM
DCrusher's Avatar
DCrusher
Lets here a AMEN to that yes it just clips on you'll need an inspection mirror just to see what's going on. It would be easier to remove the NSS for right now just to give you more room.
bphirt1
Sep 22, 2020 09:52 AM
Tbonedog
Aug 9, 2017 02:12 PM
Notmeofficer
Mar 25, 2014 03:05 AM
DznyRulz
Mar 11, 2010 11:32 PM
jsalty
17
Aug 11, 2009 09:24 PM
