1978 - 1996 Big Bronco
skyjacker lift
Old 06-21-2013, 03:57 PM
memphis88's Avatar
memphis88
memphis88 is offline
skyjacker lift
I'm lookin at getting a skyjackers lift kit for my truck and the only things it says I'll have to buy separately are the Pitman Arm and Struts. A buddy of mine recently put a lift on his Cherokee. Well we went playin around in the mud and ridin around on some trails, and after about 45 minutes his jeep started making a horrbile grinding noise. Come to find out what his front drive shaft had been stressed too much from being pulled with the lift kit and ended up shearing.
So my question is after all that is if I put a lift on my truck will i run the risk of the same thing happening or any possible issues at all?
Here's the link to the lift: http://www.summitracing.com/parts/sja-184bks/overview/year/1988/make/ford/model/bronco
Thanks for any input!
Old 06-21-2013, 04:01 PM
Kemicalburns's Avatar
Kemicalburns
Kemicalburns is offline
i am running a 6" lift and didnt require any drive shaft mods.
i will say that lift you linked is very expensive for what your getting. especially since it doesnt include extended radius arms or shocks. You really should do some more shopping around. Summit is spendy.
get yourself a 4wd magazine and look in there at prices.
Old 06-21-2013, 08:07 PM
memphis88's Avatar
memphis88
I noticed that about summit. I've looked thru a few 4wd magazines but most of what I've seen is usually jeeps or yotas. I'm only wanting about a 4 inch total.
Old 06-21-2013, 09:10 PM
greystreak92's Avatar
greystreak92
greystreak92 is offline
Agreed, that is a hefty price tag for what you are getting. I paid about that much for my complete Tuff Country 4" lift and it included longer radius arms, brackets and all 6 shocks! Granted they were crappy shocks and I replaced them within two years but I added full rear leaf packs for only about $400 more than the total in that link.
Tuff Country
Superlift
Skyjacker
Pro Comp
Rough Country
BDS
All of the above make suspension lifts. Do yourself a huge favor and research this topic to death BEFORE you buy something. There are quirks and limitations to each product line and some manufacturers just churn out "generic kits" that will fit but won't last or will leave you with a lousy ride. There is a huge amount of information available on this topic but the BEST advice anyone can give you is to research it for yourself and make a well-educated decision about a product and modification that can either greatly improve the quality and capacity of your truck's suspension performance OR it can ruin it in short order. You will be modifying the very components that hold your truck on its wheels and keep its wheels in touch with the ground. The time taken pays off in a lift that performs just as beautifully as it makes the truck appear.
Old 06-21-2013, 09:52 PM
Raleigh1's Avatar
Raleigh1
Raleigh1 is offline
Old 06-22-2013, 08:52 PM
Kemicalburns
Originally Posted by Raleigh1
Thats not a bad price for what your getting.
Old 06-23-2013, 12:58 AM
Raleigh1's Avatar
Raleigh1
Raleigh1 is offline
Or look around on Craigslist and find a 78/79 D44 and do it up right with an SAS!!!
Old 06-23-2013, 04:01 PM
greystreak92
"Right" and SAS in the same sentence is a highly questionable statement.
Old 06-24-2013, 07:19 PM
Raleigh1's Avatar
Raleigh1
Raleigh1 is offline
Bwahaha, I suppose you're right, not everyone does quality work or has enough knowledge to do a SAS.
Old 06-24-2013, 09:23 PM
greystreak92
Nor does everyone ascribe to the rather archaic notion that a solid axle is the "end-all" answer to suspension lifts and ride quality.
Old 06-25-2013, 02:45 PM
memphis88's Avatar
memphis88
another question, if i just wanted to level out the front end and raise it about 2 inches what would be the best bet on that?
on another note; does anyone on here know anything about making a prerunner out of a bronco? i saw one when i was down at Pismo beach last friday. I thought it was a really wicked concept after watching a few videos of em.
Old 06-25-2013, 02:50 PM
Kemicalburns
for a prerunner setup you will need Cut&Turned beams, extended radius arms and so forth. Plenty of shops in Cali produce these products, just do some searching online.
Old 06-25-2013, 06:54 PM
Raleigh1's Avatar
Raleigh1
Raleigh1 is offline
Whoa man, wasn't implying that at all.
SAS is definitely not better for ride quality, it really depends on what you're going to do with the rig. I personally like to crawl, so that is what I prefer, not everyone wants to go that route.
73strokin
03-03-2007 09:41 PM
lilbob1131
Aftermarket Products
04-03-2006 01:23 AM
littlefoot
09-06-2004 03:06 PM
TigerfaninNC
05-04-2004 01:51 PM
GeoTracker
04-24-2003 10:00 PM
Quick Reply: skyjacker lift
