Would you stay away from purchasing this truck? (Transfer case problems)
Old 06-25-2013, 02:53 AM
MichiganMikey's Avatar
MichiganMikey
MichiganMikey is offline
I am new here and do not own a ford yet but have been in the market for one. I found a 2006 F-150 Harley Davidson Edition 4x4. It has 63k miles on it and is in near perfect condition, except for one problem. The seller has removed the front drive shaft due to noise coming from the transfer case. This is what he stated in his advertisement:
"I have the front drive shaft taken off the truck so it is only 2WD (Rear) at the moment. It is perfectly safe and drivable without the front drive shaft on. I have been driving it for about a year like this. If I put the Front drive shaft on it feels like either the front Differential Ring & Pinion Gear is worn and has bad contact or the Transfer case chain is loose causing it to skip. The engine, Transmission, and other drivetrain parts are perfectly fine. Don't let this small issue deter you from an excellent buying opportunity."
I have heard that this could possibly be a common problem with this year model truck and maybe a bad solenoid or sensor replacement would fix it. Worst case scenario, it needs a new or rebuilt transfer case, anyone have a ballpark estimate what that would cost? Would you stay away from this truck with this problem? It is priced about $6k below book value and seems to be a pretty good deal to me. What say you? Thanks in advance for any input. Cheers!
Old 06-25-2013, 05:46 AM
60DRB's Avatar
60DRB
60DRB is offline
About this much;
2006 FORD F-150 Parts - TascaParts.com
Plus labor.
It's always buyer beware... Have the truck checked out by a mechanic.
Old 06-25-2013, 12:18 PM
skunkoffroad's Avatar
skunkoffroad
skunkoffroad is offline
It might be a IWE issue do a search, read up, then go look at it.
Old 06-25-2013, 02:28 PM
70f100longbed's Avatar
70f100longbed
70f100longbed is offline
I second the possible IWE problem. I haven't seen many transfer case or front diff failures. One of the hubs could be leaking vacuum and the resulting grinding noise is mistaken for a transfer case problem.
Old 06-25-2013, 03:30 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
Originally Posted by 60DRB
About this much;
Plus labor.
Just FYI, the two posts you made where you linked to Tasca Ford don't show any parts, just the front search page for Tasca Ford parts.
Stewart
sasquatch16
2017+ Super Duty
12-22-2018 02:16 PM
Shepc663
1997 - 2003 F150
08-20-2017 06:00 PM
blk88notch
1999 to 2016 Super Duty
01-11-2011 08:16 PM
$Simpleman76
04-14-2007 11:50 PM
nike_z
03-26-2003 03:33 PM
Quick Reply: Would you stay away from purchasing this truck? (Transfer case problems)
