dip stick leak
Old 06-17-2013, 10:26 AM
bearhugger's Avatar
bearhugger
bearhugger is offline
dip stick leak
While on vacation,dip stick gasket went out and i had to put jb weld water putty on it,it got me home but is leaking again,need to find where i can get that repair kit and the best place to get the gasket,might not ever get that jb water putty off but have to try.
Thanks Jim
Old 06-17-2013, 03:49 PM
rodneywar's Avatar
rodneywar
rodneywar is offline
riffraff sells the repair kit good price!!
Old 06-17-2013, 06:20 PM
427 fordman's Avatar
427 fordman
427 fordman is offline
If I remember right, Glenn didn't have much luck with that kit. Some have, some haven't. I hope your mechanic does Jim. There is an EXPENSIVE fix for it, I don't remember who sells it though. Someone will. It's like 300 bucks though. Edit: It may be strictly diesel.
Old 06-18-2013, 12:13 PM
RÖENTGEEP's Avatar
RÖENTGEEP
RÖENTGEEP is offline
FOREIGN GURU
Wink
Strictly Diesel Dipstick Adapter Repair Kit
Old 06-18-2013, 01:13 PM
fordman67's Avatar
fordman67
fordman67 is offline
yea...that's now on my new engine to install list!! dead sexy...and no chance of leaks!!
Old 06-18-2013, 04:02 PM
427 fordman
Thanks Jose.
Old 06-18-2013, 05:15 PM
bearhugger's Avatar
bearhugger
Thanks guys,i will do something before long.
Jim
Old 06-18-2013, 05:28 PM
bearhugger's Avatar
bearhugger
Has anyone ever used this type of seal.
Jim
Old 06-18-2013, 05:42 PM
427 fordman
The expensive one I know a couple people who drop in here once in a while have used it and said it worked excellent. I don't remember who though. The cheap fix, like I said, I've heard some have luck with it, some don't.
Old 06-19-2013, 09:42 AM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
The diesel O ring kit has a big O ring that goes on the inside of the dip stick flange as you hold it with a wire brush in the hole. My problem was trying to keep the O ring in the grove as you put it back together again. The O ring is slightly smaller then the grove and kept slipping out of the grove on me!! I finally used 'marine tex' I got on ebay all around it and it hasn't leaked yet. On my newer dually, if it leaks I will buy that expensive thing in the link above.
Old 06-19-2013, 04:51 PM
bearhugger's Avatar
bearhugger
Thanks guys,i will give a notice when i do get it fixed.
Jim
Umlify
2017+ Super Duty
13
07-31-2017 07:26 AM
Bearhugger1933
10-02-2014 07:03 PM
CLSE
1999 to 2016 Super Duty
02-22-2011 05:45 PM
cgrushian
1978 - 1996 Big Bronco
07-12-2004 09:26 AM
ckrussell
04-20-2001 10:32 PM
Quick Reply: dip stick leak
