7.3 knock issue or??
Old 05-29-2013, 01:21 PM
20powerstroke02's Avatar
20powerstroke02
20powerstroke02 is offline
Hi I bought this van not running well I got it to run! Rebuilt the oil cooler then re did all the injector o rings. 50 cent mod while I was in there. Anyways. Ive been fighting getting all this old coolant out of the oil and I got it pretty good now. So I fire it up and I have a strange thumping sound. Maybe I didn't torque an injector down right? I'm looking for ideas on what it could be. Compression going past o rings? I read possibly a cracked flex plate? There are no stored codes. Maybe I just need to drive it more since I haven't ran it much since I put the injectors back in?
That's a video of it running if anyone needs more info let me know. One thing is the ebpv thing was wired open and the flap is stuck wide open now. I don't think that would affect it.... And my alternator is cracked pretty bad I'm going to pull the belt off and spin it see if that's making the thumping sound. Thanks for any help guys.
Old 05-29-2013, 01:27 PM
20powerstroke02
That video sucks its hard to hear the thumping in it. It's obvious in person but not on a camera!
Old 05-29-2013, 02:08 PM
20powerstroke02
I'm really thinking something is wrong with the hpop because when I let it sit its a pain to start again and my oil is high. So the check ball isn't holding my oil in the hpop?!?!
Old 05-29-2013, 02:31 PM
Kdr358's Avatar
Kdr358
Kdr358 is offline
These trucks will act strange if there is air present in the HP oil and fuel system. Is should clear up within 50-100 miles. It's hard to tell from the video though. I would go run it around the block a few times and give the air a chance to purge.
Old 05-29-2013, 02:42 PM
20powerstroke02
Ya sorry that video sucks. Ill give that a shot though. My oil is turning milky again I'm having a hard time getting all the coolant/water out.... Guy I bought it from had a bad oil cooler and called the motor blown..
Old 05-29-2013, 04:23 PM
Brother Les's Avatar
Brother Les
Brother Les is offline
What are your thoughts on this 'motor blown'? Cracked block/heads? How are we sure that the oil cooler was bad and it is now not leaking?
Old 05-29-2013, 04:58 PM
20powerstroke02
I had another thread about that issue. I ran multiple tests and I know for a fact that oil cooler was the issue. Filled resivoir 8 hours later my water is in the oil pan pull oil cooler and find bad o rings and ripped gasket on back side of oil cooler that someone tried to use sealant on to fix it. Log story short out oil cooler back on and it held te water for 48 hours didn't change at all nothing came out ofte oil pan.
Old 05-29-2013, 05:04 PM
20powerstroke02
He claimed it smoked white very bad. Not sure if this was the issue but I found multiple injector o rings rotted away as well.
Old 05-29-2013, 11:27 PM
20powerstroke02
What would symptoms of cracked block or head be? I can look into that also. I'm open to all ideas. I doubt that's the problem but I'm open to the thought.
Old 05-30-2013, 05:53 AM
trk98's Avatar
trk98
trk98 is offline
I see you have 235k on it. Maybe tugly or someone more experienced than me can chime in about tired injectors. I not comfortable condemning them but my first instinct is to suggest a noisy injector. If noting else here's a bump for ya.
Old 05-30-2013, 07:34 AM
Tugly's Avatar
Tugly
Tugly is offline
I hear a dead hole. Flip the oil filler cap on the tube and see if it blows off.
Old 05-30-2013, 09:48 AM
20powerstroke02
I did the oil cap trick as soon as I got it running. Doesn't blow the cap off. Ill try to get you guys a better video today. I agree though it really does sound like a dead cylinder maybe? I'm really confused on it though because I have no check engine light... Wouldn't a dead injector make a check engine light go off? In going to use a thermometer on the exhaust manifolds today to see if its an injector. Keep in mind also there is air in the HPOP system and there still might be some in te fuel system. I haven't ran this very much since I got the injectors in. I can't tell if you guys notice but when I rev the engine it does shake a little it reminds me a lot of when I had air in my fuel system on my truck. Ill get you guys a better video.
Old 05-30-2013, 10:07 AM
CampSpringsJohn's Avatar
CampSpringsJohn
CampSpringsJohn is offline
If this is left over, you need to get it out. I would pressurize the radiator and leave it for a while and see if it pushes any more water into the crankcase. A fair amount of oil sits in the heads that doesn't run out when you change it. You also might want to suck the oil out of the HPOP in case there's water sitting up there. But if you had the injectors out, that should have gotten the water out of the heads and HPOP.
Would there be anything wrong with draining the oil and removing the oil filter, then, with the filter removed, and the drain cap removed, pressurize the coolant system and see if any water starts coming out?
Old 05-30-2013, 10:20 AM
Tugly's Avatar
Tugly
Tugly is offline
Foam in the oil part of a HEUI injector can wreak havoc. If the stick gets the command to fire and there's no open solenoid coil, then there is no sensor that actively says you have a dead cylinder (well... other than your butt). You really need a scan tool to properly resurrect a 7.3L.
Old 05-30-2013, 11:01 AM
20powerstroke02
Ok here is exactly what I did. Before I took this thing apart I drained all the oil. Fill te resivoir with water and waited 12 hours went back to the van and the resivoir was empty. So I pulled te oil plug and there's my water. This guy claimed he had the oil cooler replaced I looked at it and if he means replaced as in a junkyard found replacement then yes he had it replaced. I took the oil cooler apart found buildup on the back matting surface on the block very bad so I used a wire wheel and it took me a little while to get it all off. Also I noticed his gasket was ripped. The rubber piece on the oil cooler gaskets to the block well the rubber part was ripped on top of all the dirt in there. Then I checked the front one.
Quick Reply: 7.3 knock issue or??
