Slip yoke seal keeps leaking, need some advice please
I got a 97 f150 4x4, 4.6 and I had the shop replace the seal 3 times and it's still leaking, the seal were the driveshaft goes into the t case, I call it the slip yoke seal, they said the bushing inside looks good, there doesn't seem to be a whole lot of play in the driveshaft, it doesn't seem to leak a whole lot, I'm about ready to just forget about it and just run it, they put a seal from oreillys in, it seem to be leaking out of the bottom hole on the seal
And I have that vintage truck, but not in 4x4
"Leaking out of the bottom hole of the seal" ?? There is a hole in the seal, other than the obvious shaft hole?
The T-case probably has a vent tube or vent valve, is it plugged with road crud, so when the T-case gets hot, the air expands pressuring the case, pushing oil out through a seal? Just thinking here.
This is an old "clunk" problem. Read some of my old post.
I never could fix it so I had to remove the ESOF and the transfercase and yoke screwup and go with a aftermarket "atlas" transfercase and redesign drive shaft.
This was serveral years ago. It has worked flawlessly since.
good luck.
good luck.
jrotten67
08-08-2019 08:37 PM
conqdad
11-09-2004 08:21 PM
fordflaresides
08-01-2004 09:20 AM
