7.3 rough idle no power no ses light
Old 05-16-2013, 09:52 PM
dustin427's Avatar
dustin427
dustin427 is offline
Hi im new to this site and have a 2001 ford f-350 as I was driving home today it started to run rough and when I stoped at a stop light it was shaking real bad and wouldn't hardly take off again. Don't have a clue where to start ive been reading some of the thread so I located the icp and unplugged it no change and it was dry. If I buy the AE scantool would it be worth the money I have two powerstrokes a 2012 and the 2001??????
Old 05-16-2013, 09:58 PM
dustin427's Avatar
dustin427
here is more info change fuel filter,oil only has 1500 miles since change 80000 miles on truck,superchip programmer,turbo back exhaust,never touched the engine except for reg. maintenance,ats transmission.
I had noticed this winter that it took a long time for the truck to warm up enough that it would have any power about 20 minutes im not sure if this is related or not ive had this truck since 2003.
Old 05-16-2013, 10:01 PM
gatormccluskey's Avatar
gatormccluskey
gatormccluskey is offline
Check fuel pressure
Old 05-16-2013, 10:04 PM
Nicmike's Avatar
Nicmike
Nicmike is offline
Veteran/Sheepdog
You should start with the UVCH with those symptoms. Sounds like you have one that might have come loose.
Old 05-16-2013, 10:13 PM
dustin427's Avatar
dustin427
thanks I will start with those and keep posting it might be a few days.
Old 05-16-2013, 10:43 PM
Tugly's Avatar
Tugly
Tugly is offline
That really sounds like the UVCH. You can ohm out each injector through the 42-pin connector (over the driver-side VC):
The last two links in my signature discuss how to troubleshoot the 7.3L, and the AE with the Ford bundle covers both generations of trucks. That should help with your decision.
Old 05-17-2013, 08:48 PM
dustin427's Avatar
dustin427
I ohmed each injector they were all 2.8 no open circuits from the 42 pin connector thanks for the pic it really helped. I will get a gauge and check the fuel pressure next.
Old 05-18-2013, 12:26 AM
Nicmike's Avatar
Nicmike
Nicmike is offline
Veteran/Sheepdog
Check the nut on the back of the IPR. It holds the magnet on along with a spacer. If it comes loose the engine will run pretty rough. The magnets have been known to go bad once in a blue moon as well.
Old 05-18-2013, 07:38 AM
Tugly's Avatar
Tugly
Tugly is offline
Originally Posted by dustin427
...80000 miles on truck,superchip programmer...
Return your tuning to stock and pull any chip when troubleshooting... many a driver has been thwarted by this alone.
Are you by chance near or below 1/4 tank?
ICP can be a question mark. Pull the connector on the ICP when idling and see what this does (you'll get an SES light until plugged back in).
Old 05-18-2013, 04:49 PM
dustin427's Avatar
dustin427
has 3/4 tank of fuel i unpluged the icp while running the idle speed changed but didnt smooth out
Old 05-19-2013, 09:22 PM
dustin427's Avatar
dustin427
I think it might be an injector is their an easy way to determine which one is bad
flyboy47
1999 to 2016 Super Duty
09-10-2018 09:00 AM
Corey Tesreau
11-04-2015 12:14 PM
Ckesey
27
03-24-2014 04:52 PM
rehpig
18
04-26-2012 09:13 AM
Quick Reply: 7.3 rough idle no power no ses light
