Heat to A/C Issues
Old 05-21-2013, 02:41 PM
mollybw's Avatar
mollybw
mollybw is offline
Heat to A/C Issues
My truck will not switch over from heat to air. I can set the settings to max a/c and on the cold from heat, and then the heat will kick on. Any suggestions?
Old 05-21-2013, 03:00 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
See HVAC FAQs. Link is in signature below.
In the future, ALWAYS identify your vehicle.
Old 05-21-2013, 04:13 PM
mollybw's Avatar
mollybw
mollybw is offline
97 ford f 150 4.6 8 cylinder
Old 05-22-2013, 06:18 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is online now
the "cold to hot" is controlled by an electric motor that moves a damper door to control the hot and cold air mixture... Is this the problem, air temp? Look up blend door - its broken. Under the radio, above the hump.
Old 05-23-2013, 08:19 AM
mollybw's Avatar
mollybw
mollybw is offline
Ok thanks! I will be checking it this weekend.
Ryland
1997 - 2003 F150
35
06-26-2015 02:54 PM
brownie83
13
11-09-2011 09:32 AM
rowekmr
06-17-2010 09:32 PM
badge250
08-19-2004 01:45 PM
big315
07-24-2004 07:10 PM
Quick Reply: Heat to A/C Issues
