1949 f6 carrier bearing
Ok guys so i need to replace the drive shaft carrier bearing on my 1949 f6... id really like to upgrade to a one peice unit if possible. I think the original parts are avalible nos still if thats not possible... i will pst in the 48 - 60 also incase someone there can help
I apologize, I did find a carrier bearing on my F6. I just didn't look forward enough. Now that I got it home, I was able to crawl underneath.
One option is going without the carrier bearing and run a bigger driveshaft like that of a late 70's Ford 4x4. You can get conversion u-joints at the local part store.
C3AZ-7025-B (replaced 8A-7025) .. Driveshaft Center Support (carrier) Bearing / Stamped with BIN: X3204G or 15039 or 550010 or 550301 or 207L or 207LO
BIN: Bearing Industry Number, what autoparts stores/bearing shops go by.
Applications: 1948/52 F2/F3/F4/F5/F6 / 1953/56 F250/350.
Available from any autoparts store as it was also used as an output shaft bearing for Ford 3 speed manuals from 1949 thru 1987!
frenchyo
04-29-2015 12:11 PM
Steven Gatley Sr
18
12-27-2014 08:16 AM
John & Old Ford
20
12-18-2013 12:37 PM
