2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Adjustable Pedals Not working
Old 05-15-2013, 10:09 AM
st381's Avatar
st381
st381 is offline
Hi all,
I just replaced the battery in my 07 EL with power seat and pedals. Everything was working fine prior to changing the battery. Now the power seat is intermittently pausing or not working when I put the key in the ignition and the wife discovered that the pedals are not adjusting. Any known solutions for this? If someone knows the correct fuses to check and the location of the fuse that would be great too.
Thanks
Old 05-15-2013, 11:04 AM
berry1234's Avatar
berry1234
berry1234 is offline
Does the button for pedal adjustment work? Have you checked all the fuses?
Old 05-15-2013, 12:48 PM
st381's Avatar
st381
st381 is offline
The button is not working. Everything was working prior to battery being changed.
Old 05-15-2013, 01:20 PM
berry1234's Avatar
berry1234
Check fuses
Old 05-16-2013, 09:16 AM
st381's Avatar
st381
st381 is offline
Now everything is working as it should which means this has become an even harder to resolve intermittent problem.
kennyf100
2004 - 2008 F150
04-16-2016 04:49 AM
HC B
1999 to 2016 Super Duty
09-11-2015 09:08 AM
gbroehl1
07-14-2010 11:02 PM
aperez
11-30-2006 11:57 AM
jtl12419
04-25-2002 06:40 PM
Quick Reply: Adjustable Pedals Not working
