Power Seat control
Old Apr 12, 2002 | 01:11 PM
jtl12419's Avatar
jtl12419
Post Power Seat control
Hello,
I just bought a used '95 Econoline conversion. Both seats have power adjustments, but do not work. Driver's seat will only go back and forward with switch, but other controls (height, tilt) do not work. Passenger seat does not work at all. Both seats have 3 motors underneath.
Where can I check the fuses? Where is the fusebox? Are the seat fuses in the power distribution box? Do I need to disconnect battery before opening/changing fuses?
Thanks alot!
Old Apr 13, 2002 | 02:30 AM
madman666's Avatar
madman666
Power Seat control
I have no clue where the fuse box is, because it’s a Van, but I assume it’s on the driver’s side somewhere under the dash, or behind a panel.
You do not have to remove the battery cable when changing a fuse.
Another thing that may be wrong are the switches for the power seat, because you said it moves forward and back I assume the fuse would be ok, but check anyway.
Supply power to the motor and see if it works, if it does then it’s the switches, if not the motors are dead, and need replacing.
If you have any more questions, just ask.
Old Apr 25, 2002 | 06:33 PM
wolfmanagh's Avatar
wolfmanagh
Power Seat control
Well if you didn't get it fixed by now, here it goes.
two of your motors are most likly bad. I'd take them out and bring them to a starter/alternator rebuilder shop. They can redo them for a lot less than new ones would cost. We did this on a 97 e350 like a year ago.
Old Apr 25, 2002 | 06:40 PM
GammaDriver's Avatar
GammaDriver
Power Seat control
brianrowe
Sep 18, 2014 08:30 AM
the-pred
Jul 28, 2011 07:40 PM
anttho
May 2, 2007 01:23 PM
