Leave Power Inverter Connected?
Old Jul 14, 2010 | 07:07 PM
gbroehl1's Avatar
gbroehl1
Question Leave Power Inverter Connected?
Ok, so I added a cheapish 400w power inverter for the upcoming trip to Indiana and then RRE to power the kid's DVD player, charge cell phones, etc. It will get upgraded to a decent unit someday but this was a last minute decision and I needed to find something locally. I ran 6 gauge wire from underneath the rear seat where I mounted the inverter all the way to the main battery. Although the inverter has a power switch which I plan on making use of, the directions say I should disconnect it from the battery when not in use. Do I need to be worried about leaving it shut off but still connected to the battery or is that just their legal department doing their duty to make sure I can't sue them
Old Jul 14, 2010 | 07:17 PM
CSIPSD's Avatar
CSIPSD
Mine has been in the tool box for about 4 years hooked to the battery. Add a fuse right after the battery and your good to go.
Old Jul 14, 2010 | 07:22 PM
shacks87's Avatar
shacks87
Mine is connected the same way, been that way for 2 years. Just turn it off at the switch and you should be fine.
Old Jul 14, 2010 | 11:02 PM
twags6's Avatar
twags6
Mine is also hooked up the same way, minus the fuse. Gotta get around to that one day. No problems so far (knock on wood).
