Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Distributor off a tooth?
Old 05-03-2013, 06:36 PM
georgieboy's Avatar
georgieboy
georgieboy is offline
I have a 1989 7.5. I installed a new distributor and it runs fine at idle and low speeds. However when pulling a hill it seems to have a lot less power than before the new distributor. Because it is in a motor home it is impossible to reach the timing mark without major removal of the front end. I have retarded and advanced the timing numerous times. It either has low power on hills or when advanced even a tiny bit it strains to crank when warm. I was told the distributor is off a tooth. Can this be true? I thought it would spit and sputter if off even one tooth. Can anyone help me? Any help is appreciated. Thanks
Old 05-03-2013, 08:09 PM
bubbasz1's Avatar
bubbasz1
bubbasz1 is offline
If the distributor was off a tooth it wouldn't run or would run terrible. I would guess that the advance, both mechanical or vacuum is off. Best way is to to check the timing, double check that during the exchange process you didn't knock a vacuum line off somewhere.>> Sorry, but I think it's time to get creative on getting a timing light in there somehow.
Old 05-03-2013, 09:54 PM
georgieboy's Avatar
georgieboy
Thumbs up Distributor off a tooth?
Thanks Bubba, I think I have figured a way to use a mirror to check the timing. I will check all the vacuum lines. A friend of mine said to check the muffler also as this thing is 24 years old and only has 40,000 miles on it and exhaust is original. He says the muffler could be filled with rust blocking exhaust. will let you know. Thanks again.
Old 05-04-2013, 08:24 AM
bubbasz1's Avatar
bubbasz1
bubbasz1 is offline
Could be on the exhaust, see if you can get a vacuum gage on it, might give you some indications of whats going on.
Red1111
03-04-2017 02:00 PM
Fetruck86
05-29-2016 08:42 AM
dsrtjeeper
55
07-14-2011 09:39 PM
adams.construction
13
05-09-2010 01:09 PM
jefferias
10-08-2004 04:06 PM
Quick Reply: Distributor off a tooth?
