Would a bad MAF sensor make the truck run super rich. My 95 f150 with a 5.0 will lug bad like fouled plugs but if I get it to drop a gear and get the rpms up it will run fine for awile. Also does anyone know why it likes to stall if in reverse and have the wheeles turned real sharp.
The codes where pulled after all this. All it had was 2 MAF sensor codes and a tranny code. The trans was just rebuilt so that shouldn't be it. But I'll get the codes pulled again and get back.
