MAF problem
Old Apr 29, 2013 | 08:38 PM
Pequeaford's Avatar
Pequeaford
MAF problem
Would a bad MAF sensor make the truck run super rich. My 95 f150 with a 5.0 will lug bad like fouled plugs but if I get it to drop a gear and get the rpms up it will run fine for awile. Also does anyone know why it likes to stall if in reverse and have the wheeles turned real sharp.
Old Apr 29, 2013 | 09:03 PM
DBGrif91's Avatar
DBGrif91
It's possible the MAF sensor is part of the problem, but the most likely cause is the O2 sensor(s). I'd recommend pulling the trouble codes.
Old Apr 30, 2013 | 08:16 PM
Pequeaford's Avatar
Pequeaford
The codes where pulled after all this. All it had was 2 MAF sensor codes and a tranny code. The trans was just rebuilt so that shouldn't be it. But I'll get the codes pulled again and get back.
Old Apr 30, 2013 | 08:22 PM
lv2race's Avatar
lv2race
Remove and clean your IAC, it may help with the low idle and stalling.
James Bibb
May 27, 2012 06:24 AM
Dre82s
Feb 24, 2008 12:26 AM
hdwideglide94
Jan 31, 2006 05:50 PM
jvaski
1997 - 2003 F150
Dec 26, 2004 06:01 PM
RADVRA
Jul 17, 2003 07:10 PM
